DDD Posted June 26, 2023 Share Posted June 26, 2023 Hi all, I am super new to the irrigation design and I started off with tutorials in the VW University. https://university.vectorworks.net/mod/scorm/player.php?scoid=32&cm=98¤torg=articulate_rise In the "placing pipe" section the video is showing new pipe drawn and connected to irrigation heads will generate flow number automatically. however, this is not the case for me, new pipes I draw are showing 0 flow number and I don't know how to fix this. Anything I could be wrong doing here? Thank you in advance, irrigation pipe flow number v2022.vwx Quote Link to comment
Jeff Prince Posted June 26, 2023 Share Posted June 26, 2023 Replying from the field, so I can’t open your file. Did you connect your pipe to a mainline, valve, and POC? Quote Link to comment
DDD Posted June 27, 2023 Author Share Posted June 27, 2023 20 hours ago, jeff prince said: Replying from the field, so I can’t open your file. Did you connect your pipe to a mainline, valve, and POC? Hi Jeff, Thank you for the reply. I figured it out. Looks if I just connect two outlets it won't return any pipe flow. I will need to extend the pipe out for it to calculate. Quote Link to comment
