Marco Zavagno Posted June 15, 2023 Share Posted June 15, 2023 Hello! we are working on a project that needs lots of imports from Revit (.rvt and IFC files) on both directions. We are now in need to move our saved vies from VWx to Revit/Naviswors, and we are trying to export toward these our cameras and their settings so to maintain the exact same views on both ends. A colleague wrote a script to do it but we are getting an error and he would need some help on this. This is the script: PROCEDURE ConvertToNavisworks; VAR hCamera : HANDLE; cameraName : STRING; xmlFile : LONGINT; { Declare xmlFile as LONGINT instead of TEXT } xmlText : STRING; BEGIN { Open the XML file for writing } xmlFile := CreateTextFile('S:/2022/2244 URWLD INTERIOR/05. DRAWING/03. MODEL/URWLD 'Clean' Model/URWLD Working File/Camera Information/cameras.xml'); { Start the XML document } WriteLn(xmlFile, '<?xml version="1.0" encoding="UTF-8"?>'); WriteLn(xmlFile, '<Viewpoints>'); { Iterate through each camera position } FOR hCamera IN ActLayer(VWCameraNode) DO BEGIN { Get the camera name } cameraName := GetName(hCamera); { Write the viewpoint element to the XML file } WriteLn(xmlFile, ' <Viewpoint>'); WriteLn(xmlFile, ' <Name>', cameraName, '</Name>'); WriteLn(xmlFile, ' <Position>', GetCameraPosition(hCamera), '</Position>'); WriteLn(xmlFile, ' <Orientation>', GetCameraOrientation(hCamera), '</Orientation>'); WriteLn(xmlFile, ' </Viewpoint>'); END; { Close the XML document } WriteLn(xmlFile, '</Viewpoints>'); CloseFile(xmlFile); END; RUN(ConvertToNavisworks); He says that he is getting an error on line #9: "identifier not declared" Any Idea? Could any of you script geniuses and wizards help? 🙂 Thanks in advance Cheers and Ciao(s) Marco Quote Link to comment
Pat Stanford Posted June 15, 2023 Share Posted June 15, 2023 CreateTextFile is not a Vectorscript command. Use Open instead, but it is a procedure not a function, so it is not going to give you the xmlFile handle. Also, only a single file can be open at a time, so WriteLN does not take a handle either, so the xmlFile portion of all the WriteLn procedures need to be removed also. And Close in Vectorscript does not use the xmlFile, but takes the same name as you used in the Open procedure. Take a look at Close in the Function Reference for an example that is close to what you are trying to do. HTH Quote Link to comment
Marco Zavagno Posted June 16, 2023 Author Share Posted June 16, 2023 Thanks a million! I will pass all this over to my brainiac colleague 'cause I reeeeeeeally dont understand anything at all! 🙂 thankuuuuuu 🙂 Quote Link to comment
