Frontal and Right components in Symbols
I also don't know about the script, but are you sure "components" will work for you?  You can't just add one object into the front component, you have to draw everything you want to be in the "orthogonal componts" as those are the only thing that will show in the component. The model does not show in the orthogonal views if there is a corresponding component.
Also, the components will only display in Viewports set the the orthogonal view and rendered in Hidden Line.
You can certainly add a planar circle to the 3D model, but it will show in all views. Your best bet may be to do that and use a Class to control the visibility.
