JonKoch Posted June 13, 2023 Share Posted June 13, 2023 I'm wondering if there's a way to hide a column on worksheets or if you just need to reduce the column width to something so small you can't see it. Thanks! Quote Link to comment
Pat Stanford Posted June 13, 2023 Share Posted June 13, 2023 Set the column width to zero is the best way. If you need it back, select the columns on both side and change the width and all three will then end up with the same width. 2 Quote Link to comment
JonKoch Posted June 13, 2023 Author Share Posted June 13, 2023 Ok, awesome thanks Pat. I had set the width to zero but couldn't get it back so that's very helpful! Quote Link to comment
