Amy C. Posted May 24, 2023 Share Posted May 24, 2023 Hello, I'm trying to make a custom curved truss, I have a DWG from the manufacture that I've used to make a symbol. I added 3D locus on the edges and middle of the truss and magnets to the edges, then used the convert to truss command. I entered the truss properties, and updated the magnets again to confirm positioning, and refresh the magnets. When I try to snap trusses together, the red line goes perpendicular to the other truss, and though they look snapped together they aren't connected (when I select system objects it selects nothing else). When I turn on centerline the centerlines are the perpendicular direction. I tried rotating my symbol and it doesn't fix the issue. Also, I can only attach motors or fixtures at one point on the truss, but then when I try to run any Braceworks calculations I get errors that the loads are not attached and truss not properly supported, even if I connect them at the one point. Am I missing something for getting these custom curved trusses to connect as a system? How can I attach motors or loads at any point along the curved truss? Thanks for your help. Quote Link to comment
Amy C. Posted May 24, 2023 Author Share Posted May 24, 2023 Some screenshots showing what I mean. First the connection line not matching the truss, second the centerline not following the truss, third the only connection point for motors or loads, but even when attached there I get a not properly supported error. Some Quote Link to comment
aheininen Posted May 25, 2023 Share Posted May 25, 2023 Hi. Is this the placement in which you have put your circle segment in symbol? Segment has to start from 0,0,0 and curve to counter clock wise in symbol definition in Resource Manager. Ask me how I know. 🙂 Been there done that. Also I can be wrong but your angle in truss properties might be too big, your connection line seems more curved than your actual truss segment. Connection line should correlate to your truss curvature. Quote Link to comment
Amy C. Posted May 25, 2023 Author Share Posted May 25, 2023 (edited) Thanks for your reply, I updated my symbol positioning to reflect what you showed, I was centered on the zeros. My actual angle is 6.25 per truss, in the screenshot above the angle is much higher. I've been trying to get the centerline on the truss and still can't. When I put the 6.25 angle and the diameter change of the truss the centerline is 3' right of the truss and the centerline is a few inches long. When I put the diameter as length to the center of the circle given that angle the centerline is the length of a single truss but is over 50' away from my truss. And it still isn't actually connecting as a system. Edited May 25, 2023 by Amy C. Quote Link to comment
Amy C. Posted May 25, 2023 Author Share Posted May 25, 2023 If I put the motors and a load on the centerline then it calculates and says everything is connected properly, it I put them on the truss itself even where it shows snap points on the centerline it won't. But the centerline is way off the truss symbol even with the truss symbol starting at 0,0,0. No matter what numbers I put in for the diameter and angle the centerline is always off the truss. The larger the diameter the further away from the truss and longer the line. With a very small diameter and angle it is close to the truss but I can't get it to be both on the truss and the right angle/length of the truss. Quote Link to comment
Vectorworks, Inc Employee JustinVanHassel Posted May 30, 2023 Vectorworks, Inc Employee Share Posted May 30, 2023 @Amy C.Do you have a test file you can send and I can take a look. I am the VW employee responsible for creating and setting up all the truss connections for the truss in the Resource Manager and I would like to see what your auto-connect settings are. Curved truss is tricky because you can set measurements from the center of the truss or the center of the arc which is controlled by a radio button in the Truss Properties window. If you share your file I can diagnose and most likely send you back a corrected file with explanation. You can either post in this thread or DM me. Justin Quote Link to comment
Amy C. Posted May 31, 2023 Author Share Posted May 31, 2023 Thanks Justin! I think I might have solved it but I just sent you the file in a DM to look over and confirm. Quote Link to comment
