b303lmr Posted May 11, 2023 Share Posted May 11, 2023 We have a Vectorworks Architect license installed on two machines (to facilitate working from home), but now want to remove the license from the WFH machine. Does uninstalling the programme from the machine free up the second instance of the license serial number to be used on a different device? If we go to remove the serial number through the 'Session' menu we can't click 'Done' as there is then no license associated with the install. Any info would be much appreciated! Quote Link to comment
Jack_Hamilton Posted October 12, 2023 Share Posted October 12, 2023 Did you find a resolution to this issue? Quote Link to comment
Pat Stanford Posted October 12, 2023 Share Posted October 12, 2023 User of serial numbers is actually controlled by "Activations" not by installs. Removing a serial number does not reset the Activation. If you have a need to activate on a different computer (new machine, HD crash, etc.) contact Customer Service and they can reset the activations. Quote Link to comment
Cookie_NZ Posted May 14, 2025 Share Posted May 14, 2025 Hi, I've just stumbled on this issue. If activations can only be reset by Customer Service, then the online manual needs updating. To remove a serial number: 1. Click Serial Number from the Session pane of Vectorworks preferences. 2. The Serial Number dialog box opens. 3. Select the serial number to remove, and then click Remove. 4. Click Done. https://app-help.vectorworks.net/2025/eng/VW2025_Guide/Start/Adding_and_removing_serial_numbers.htm As noted by @b303lmr this is not possible, as 'Done' is greyed out. Cheers, Cookie Quote Link to comment
Pat Stanford Posted May 14, 2025 Share Posted May 14, 2025 I have just filed a bug on this VB-211862. 1 Quote Link to comment
