Thomas W Posted April 26, 2023 Share Posted April 26, 2023 Hi all, Should all functions available for DoMenuTextByName be available in the online and/or local version of VS:Function Reference Appendix H or am I missing something? I found the function 'Fit To Objects' on the forum but not in the help, is it an oversight in the help or is there other places where these functions are available? I'm working on a French version. Thank you and good day, Thomas Quote Link to comment
Pat Stanford Posted April 26, 2023 Share Posted April 26, 2023 I keep submitting bugs to try and get both version of the help complete synced. What are you seeing different between the Developer site and the local help? Quote Link to comment
Thomas W Posted April 27, 2023 Author Share Posted April 27, 2023 Bonjour Pat, Je n'ai pas vu de différence entre le site du développeur et l'aide local mais la fonction 'Fit To Objects' n'est pas présente, seul la fonction 'Fit to Window' est présente. Merci et bonne journée Quote Link to comment
MullinRJ Posted April 27, 2023 Share Posted April 27, 2023 (edited) No, not all menu items can be called by DoMenuTextByName(). Sorry. And the documentations is also incomplete. What functions are you trying to use? If after trying what you think should work, and any variation of that command that seems reasonable and your attempts don't succeed, check back to this Forum. You will probably get a very quick confirming answer from someone who has tried before. If you are really lucky, you will get the name of a command that will work. All the best, Raymond Edited April 27, 2023 by MullinRJ 1 Quote Link to comment
Thomas W Posted April 27, 2023 Author Share Posted April 27, 2023 The function DoMenuTextByName('Fit To Objects',0) worked fine for me even though I couldn't find it in the help (but on this forum)! Thanks for your feedback, Thomas Quote Link to comment
