Tom W. Posted April 22, 2023 Share Posted April 22, 2023 When I apply an offset to the stringer: ...only the stringer should move, not the risers as well: 300mm offset applied for illustrative purposes!: (not sure if this intended behaviour or a bug) Quote Link to comment
0 zoomer Posted April 22, 2023 Share Posted April 22, 2023 I would need the riser cover 15 mm offset and tread cover 40 mm offset .... Basically the only reason why I used the Stair's IFC Solids import and gave up with the VW Stair. (OK, and that I have better and healthier geometry ....) Quote Link to comment
Tom W.
1 answer to this question
