cberg Posted April 21, 2023 Share Posted April 21, 2023 Can a worksheet be summarized by two columns of values? For example, I would like to first organize my worksheet by department, which I have put in the "Occupant Type" Field. And then summarize the items by the custom space name. I want the worksheet to communicate the following: In the RH Regional Group, there are “x” 6’ x 8’ cubes. In the R2 Homes Group, there are “y” 6’ x 8’ cubes. In that way, one can review the building program by department. I know I can make separate worksheets for department and summarize the values. Is there a way to build these worksheets into a master worksheet? Or is there another way to do this? Quote Link to comment
Pat Stanford Posted April 21, 2023 Share Posted April 21, 2023 You can SUMmarize on multiple columns. When you add the first SUMmarization (Department in your case) it will collapse everything into a single subrow by the values in that column. When you then add a SUMmarization to the second column (space name) it kind of does an "unsumarization" and will then show a subrow for each unique value for Spacename in each Department. It is easier to do than to explain. Try it and ask again if you still need help. 2 Quote Link to comment
cberg Posted April 21, 2023 Author Share Posted April 21, 2023 That's exactly what I needed, thank you. Quote Link to comment
