Railing - Is is possible to delete one or both end posts?
CW2020
If I understand correctly, seperate 3D railings with different slopes can not be connected/joined? If that's the case, I'd like to remove one or both posts at a given location as a workaround. Is this possible? As a test I did center posts from different segments, but as expected it's just not a clean fix (see attached). And yes, I imagine there's a better approach, but I landed on this one and only want a slightly cleaner result.749098252_ScreenShot2023-04-13at1_16_03PM.thumb.png.270ed9f3b3075262b3cd1b3f4a6948ce.png
Thanks for the quick reply. Ya know I tried that previously though (did you mean "uncheck" or am I getting confused?) and it didn't seem to work. I tried it with a stock railing symbol just now, and it worked perfectly. Maybe it's because I created a custom railing symbol. I'm attaching both railings in case you or someone else is curious.
RAILING - 2.vwx
