I'm getting to grips with the railing/fence tool and have used the settings to edit it visually. Under settings - 3D attributes - Panel, I've added a material ("Siding Vinyl Beaded Seam Tan 6in MT") which when used on a wall, this material is horizontal, however on my fence panels it's showing vertically. Same thing happens with any other texture. Is there anyway I can rotate this? Without directly editing the material, as I have used this elsewhere in my project. The second image attached, with the blue panels, same problem but wierdly the end panel has the correct orientation.
K.E
1 answer to this question
