I am currently modelling a house and when I attempt to draw a dimension on a particular elevation (view) of the house it appears on the elevation (view) directly behind. If I then view the elevation the dimension is incorrectly displayed on its actually also in reverse, as if it has moved through the building.
I don't know if its coincidence or relevant but two elevations (views left and back) display the dimensions correctly when drawn on the surface of the walls and the other two opposing elevations (views right and front) do not and display as I have mentioned above. Further, the views which display the dimensions correctly are also directly connected to the internal origin and X,Y and Z axis.
In addition to the above I have also realised the issue isnt related solely to dimensions. If I draw a line or a rectangle on the right and front view these objects also move onto the wall of the left and back views (which as I mentioned above also happen to be aligned with the internal origin and X,Y and Z axis.
Does anyone know why this would be happening and how i can fix it? I have attached Images below for reference.
Right view (the wall which the dimension should be on and the view which was selected to draw it on)
AlexanderWalker
Hello
Left view (wall dimension appears on incorrectly)
Alex Walker
PC
Windows 11
v2023 SP1
Edited by AlexanderWalkerAdditional information
8 answers to this question
