Cristiano Alves Posted December 14, 2022 Share Posted December 14, 2022 Hello I dont know what happend but mu barriers change the texture to white. But if i change the barriers to another Design layer, the textures its good. Any idea to fix this? Thank You so much Quote Link to comment
Pat Stanford Posted December 14, 2022 Share Posted December 14, 2022 Check your layer options. It looks like you might have them set to Grey Others. 1 Quote Link to comment
Cristiano Alves Posted December 14, 2022 Author Share Posted December 14, 2022 27 minutes ago, Pat Stanford said: Check your layer options. It looks like you might have them set to Grey Others. Thank you for your anwser. I had already tried to change all the settings and none of them worked correctly. I usually always use: "Show/SNap Others" Quote Link to comment
Pat Stanford Posted December 14, 2022 Share Posted December 14, 2022 I misread your post. So the object changes colors when you move the object between layer? Not when you switch the active layer? Are you using Layer Colors? Have you restarted VW? Can you post a sample file showing the problem? 1 Quote Link to comment
Cristiano Alves Posted January 4, 2023 Author Share Posted January 4, 2023 Sorry, I'm starting work on NYE shows and need to stop this project. I figured out that the problem is a relation between my class a_Show-Barrier and my class a_Show-Lighting-JDC1. If I delete the class a_Show-Lighting-JDC1, the barriers have the nice texture again. I tried to figure out the relationship and the some colour setting without success. In the attached files, you can find the example project. I appreciate your help." MODJO White- v1.vwx Quote Link to comment
Pat Stanford Posted January 4, 2023 Share Posted January 4, 2023 Student Edition file can't be opened with my Professional version, so I can't take a look at the file. 😞 Based on your description, it sounds as if either the barriers or subparts inside the barrier object have the class a_Show-Lighting-JDC1 assigned. And that class has no texture assigned. And the objects are set to Use Class Texture. HTH Quote Link to comment
Cristiano Alves Posted January 11, 2023 Author Share Posted January 11, 2023 On 1/4/2023 at 11:48 PM, Pat Stanford said: Student Edition file can't be opened with my Professional version, so I can't take a look at the file. 😞 Based on your description, it sounds as if either the barriers or subparts inside the barrier object have the class a_Show-Lighting-JDC1 assigned. And that class has no texture assigned. And the objects are set to Use Class Texture. HTH In fact i found the problem. The JDC1 are ON. WHen I turn OFF them all the textures are ok. Thank you so much for try help me. Quote Link to comment
