DAM64 Posted December 6, 2022 Share Posted December 6, 2022 VWX crashes immediately when I try to select 'Printer Setup....' from the 'Page Setup...' dialog via 'File' drop down menu. This does NOT happen with regular non-shared VWX files. Work and Project file are saved in a local DropBox folder (offline access enabled) Suggestions appreciated. VWX 2023, macOS Ventura 13.01 MBPro 16", Radeon Pro 5500M 8GB & Intel UHD630 32GB RAM, 1 TB SSD Dual external Monitors Quote Link to comment
0 Administrator JuanP Posted December 6, 2022 Administrator Share Posted December 6, 2022 @DAM64 Try the following : Quote Link to comment
0 DAM64 Posted December 6, 2022 Author Share Posted December 6, 2022 Thank you Juan. Did not work - dropping the script onto icon in dock does not work. The script is from 2002... and the post is from 2017. No expert on the print system in ventura but cant help but wonder if they changed and broke a few things? The issue only happens to a workfile, not with a regular file. And it never happened with 2022. Appears to be issue with 2023 and Ventura. Quote Link to comment
0 DAM64 Posted December 6, 2022 Author Share Posted December 6, 2022 2 hours ago, JuanP said: @DAM64 Try the following : @JuanP Didn't work, please see earlier comments as well Quote Link to comment
0 DAM64 Posted December 7, 2022 Author Share Posted December 7, 2022 After some searching, WAS able to run the script via Tools Menu ---> Plug Ins--->Run Script... (drop on icon route does not work) Crashing problem appears solved. 2 Quote Link to comment
DAM64
32GB RAM, 1 TB SSD
4 answers to this question
