I'm using VW 2022 on both Mac and Windows and neither will render a Top view as a Dashed Hidden Line. I can't say for other views for sure, but I think they work. I do not have the Viewport set to "Top/Plan." It is set to "Top." It renders fine as a dashed hidden line in the design layer, but when I make that design layer view into a viewport, the viewport will not render with dashed lines. It just renders as an ordinary hidden line. At least it renders as a hidden line after I give the objects a fill, remove the fill, give it a fill, and remove the fill. No chanting required, however. This is not a problem with my file nor with my particular installation. It is a problem with the VW2022 software. My question is if this has been fixed in either service packs for 2022 or in the new version 2023. I do need to install some service packs.
MGuilfoile
Thanks for any info on this!
MHBrown
0 answers to this question
