BGD Posted October 3, 2022 Share Posted October 3, 2022 Hi, Can you please suggest easiest way to draw a curve mirror that is standing on ground? I need to draw a mirror that makes a person looks smaller. Thanks for your help Quote Link to comment
mjm Posted October 3, 2022 Share Posted October 3, 2022 HEY @BGD I have attched a quick mirror drawing. draw w/ Double Line w/ 3 points in a shallow angle shape (I made it 3" wide) with that shallow angle poly selected, hit the minus key (edit by points) I used the fourth curve type. click once on the two center point et voila! we have a curved poly. Extrude that poly as you see fit Extract the surface and move the extracted surface about 1/32" away from surface choose or make a mirror Texture resource and apply. I made both vertical surfaces mirrors in the attached file. Mirror.vwx 1 Quote Link to comment
