LivingEarthDesign Posted September 27, 2022 Share Posted September 27, 2022 Does anyone know if its possible to use globe plants 3d product in vw? and if so how?! help! Quote Link to comment
Jeff Prince Posted September 27, 2022 Share Posted September 27, 2022 Those are best used in the software and render engine they are designed for. Bringing them into Vectorworks is possible but leads to poor results. Quote Link to comment
Vectorworks, Inc Employee Ben Beaumont Posted September 28, 2022 Vectorworks, Inc Employee Share Posted September 28, 2022 There are a couple of ways to use Globe Plants. 1. Globe Plants will sell you image files for which you can create Image Props. [Very quick and effective.] 2. Use Enscape and place the Enscape Asset in Vectorworks and render in Enscape. [Amazing results.] Quote Link to comment
LivingEarthDesign Posted September 30, 2022 Author Share Posted September 30, 2022 On 9/29/2022 at 9:15 AM, Ben Beaumont said: There are a couple of ways to use Globe Plants. 1. Globe Plants will sell you image files for which you can create Image Props. [Very quick and effective.] 2. Use Enscape and place the Enscape Asset in Vectorworks and render in Enscape. [Amazing results.] Thanks for your help, what type of file format of theres would be best for option 2? i want to do a test run Nat Quote Link to comment
Vectorworks, Inc Employee Ben Beaumont Posted September 30, 2022 Vectorworks, Inc Employee Share Posted September 30, 2022 Hi Nat, if you're wanting to use images, then .png supports alpha channels (transparent background) which you'll need for Image Props. If you're wanting to use the mesh objects in Vectorworks (Caution!*) then Globe Plants will provide low poly .obj files. Are you aware there are sample files in our (Australian and New Zealand) libraries? In 2023 you will find them in the RM via: Vectorworks Libraries > Plants > _Plant (styles) > ANZ Globe Plants Sample Pack (mesh).vwx and Vectorworks Libraries > Plants > _Plant (styles) > ANZ Globe Plants Sample Pack (Props).vwx There are also Image Prop symbols in both formats for Architects. For Enscape, contact Globe Plants. They will set you up with the Enscape Assets that you'll need to install into Enscape. From memory the assets will be revealed in the Vectorworks Enscape Plug-in widget. I have seen a User successfully associate these assets with the 3D components of Plant Styles. However I haven't tested this. [*As @jeff prince intimates, the mesh objects tend to be heavy and you'll take a performance hit. Use with caution.] You can contact us directly for Support. Quote Link to comment
skeyshubber Posted March 13, 2025 Share Posted March 13, 2025 I have been using Globe Plants and Enscape for my renderings and love it! My question is.....Enscape w/VW is only compatible for low poly models. There seems to be a greater variety of high poly models available and usually the type/species that I want/need. Is there any way to utilize high poly models in VW or, better yet, is there a way VW can accept high poly models? Quote Link to comment
