TMM Posted September 19, 2022 Share Posted September 19, 2022 1. how to create a 3d wall as the image below in vectorwork? 2. Is it possible to create a 3d object of the wall and assign structure and materials to it? (I don't think I could add structural components or material layers in the 3d objects. Not sure.. Thanks! Quote Link to comment
Tom W. Posted September 20, 2022 Share Posted September 20, 2022 1. Use 3D Wall Hole Component symbols to clip the holes in the Wall + the Reshape Tool to create the angle on the side. 2. You can assign Materials to 3D objects + therefore report on them in the same way as Wall components which are using Materials. If you check 'Merge With Structural Objects in Sections' in the OIP for those 3D objects you can merge them with Wall/Slab/Roof components in section VPs so that they are indistinguishable from those components. 2 Quote Link to comment
TMM Posted September 20, 2022 Author Share Posted September 20, 2022 Thanks Tom, But the reshape tool only allows me to change the peaks of the wall vertically, not horizontally. Did I do something wrong? Thanks! Quote Link to comment
Tom W. Posted September 20, 2022 Share Posted September 20, 2022 Add the necessary vertices + you can create whatever shape you want. Quote Link to comment
TMM Posted September 20, 2022 Author Share Posted September 20, 2022 I did add vertices in the reshape tool, but the corner point could not be dragged horizontally, but only vertically. Any solution? Quote Link to comment
Tom W. Posted September 20, 2022 Share Posted September 20, 2022 See: Screen Recording 2022-09-20 at 19.34.56.mov You can do quite a lot with the Reshape Tool. This is a combination of a wall hole symbol + the Reshape Tool: 3 Quote Link to comment
TMM Posted September 20, 2022 Author Share Posted September 20, 2022 Amazing! Thanks! Quote Link to comment
