TMM Posted September 19, 2022 Share Posted September 19, 2022 I know people have asked and I have watched these threads. First, when people say find a instance/component that has 3d wall hole component and edit it. But where? Do they mean find a door, a window to cut an opening? Second, people also mentioned to make a personal component and add a 3d wall hole component inside. I did that route, but now could I delete the original object that I created fro the 3d wall hole component? Image attached below, as you can see , the first rectangle of the component is still there after the 3d wall hole component! How could I get rid of it??? Thanks! Here is the link that I watched the video: Quote Link to comment
Tom W. Posted September 20, 2022 Share Posted September 20, 2022 To create a Wall Hole Component symbol just create a new symbol, place 3D geometry in the 3D Wall Hole Component + a 3D Loci in the 3D Component. If I understand your post correctly, all you need to do is delete the Extrude that you've placed in the 3D Component + replace it with a 3D Loci. 1 Quote Link to comment
TMM Posted September 20, 2022 Author Share Posted September 20, 2022 you are life saver!!!! Thanks! 1 Quote Link to comment
