newbie q - texturing pios
zero
Hi all
So I insert a pio which uses 3 different classes.
Each class I ser to 'use textures a creation' and give them a tex...
Question is: how do you edit the textures for the individual objects within the pio ?(classes), eg scale , rotation, etc?
Thjnaks
Hello zero:
The mapping is determined by the plug-in author. If you want to have a different size you can modifiy the texture resource's size. Otherwise if you need a different mapping you would have to convert the plug-in to a group so that you could edit the mapping on the sub-geometry.
