Kjonz58 Posted September 7, 2022 Share Posted September 7, 2022 Hello, thanks for reading. I thought I was an "Intermediate" VW user, now I feel like a Beginner again. I have imported someone else's 3-D file of our black box theatre space. Into this I have extruded audience risers, and a few simple 3-D set pieces. I assigned a fill to each, but none of these fills appear in Final Renderworks. Why is this? I have even created a separate Class AND Layer for each of these objects. I'm sure I have inherited something in some Class that is blocking these fills, but have no idea how to continue. Thank you! Quote Link to comment
0 michaelk Posted September 7, 2022 Share Posted September 7, 2022 If they are all extrudes it’s possible that the polygons are not closed. Double click the extrude to get back to the polygon. Select it. Look in the OIP. If “Closed” is not checked, check it. mid that doesn’t do it copy and paste the objects into a blank document and post it here. Quote Link to comment
0 Kjonz58 Posted September 7, 2022 Author Share Posted September 7, 2022 These are all closed polygons. Rectangles, in fact. Very simple geometry. I suspect the glitch is between VW 2022 and the file I inherited which is 2020??? It did finally apply a Fill to each object, but that fill is BRICK. I don't want brick. Why does it insist I want brick??? Quote Link to comment
0 michaelk Posted September 7, 2022 Share Posted September 7, 2022 There is almost certainly no issue between 2020 and 2022. There is a difference between a fill and a texture. A texture is like a fill, but for 3D. I suspect you have a texture applied to the objets. Select one of the objects. At the top of the OIP there are 3 tabs: Shape | Data | Render. Choose Render. Under Texture it probably says Overall then below that is the name of a texture. Probably Brick something. Click on that name. Right below that is a label Texture: with a pull down. Make that pulldown say "None". Quote Link to comment
Kjonz58
3 answers to this question
