This is my first post - I'm an ex Autocad drafty, new to vectorworks, completing tutorials & learning as I go so please bear with me.
I am using it for civil/structural drafting Australian residential/small commercial structures.
I typically only use a select few cross-sections for standard 'off the shelf' steel members (I-Beam, Angle, Tee, Round Tubing, Square tubing.. etc) that are typically used in Australia for construction so my question is based on streamlining the drafting process to save time.
QUESTION I want to reduce the number of options available in the dropdown menus for each type of object so that only the 'ANZ' series show.
See screenshots below - I do not need any of the others (for other counties). Is there a way to remove all of the other options?
e.g. when I insert an Angle, I only want the option to select either:
Aaron Veale
Hi folks,
QUICK INTRO
QUESTION
ANZ Equal Leg Angle
or
ANZ Unequal Leg Angle
Thanks.
Regards,
Aaron Veale
1 answer to this question
