Jack2022 Posted August 14, 2022 Share Posted August 14, 2022 Hi All, I had raised the issue of how to make a hardscape have a tapered component before and the result was that they can't. i.e they can't have a sloped top and a fixed bottom. Well I've just found the solution which is slab drainage! Brilliant! Question: in the UK we show falls as a ratio not percentage. Is it possible to show the falls/ gradients as a 1:x ratio?? Many thanks. Quote Link to comment
Tom W. Posted August 14, 2022 Share Posted August 14, 2022 7 minutes ago, Jack2022 said: I had raised the issue of how to make a hardscape have a tapered component before and the result was that they can't. i.e they can't have a sloped top and a fixed bottom. See: Quote Link to comment
Jack2022 Posted August 14, 2022 Author Share Posted August 14, 2022 Quite right Tom. I didn't explore slab drainage enough before moving on. Any advice on showing the grades as ratio not %? Thanks Quote Link to comment
Tom W. Posted August 14, 2022 Share Posted August 14, 2022 I don't believe you can show the grades as ratio you might need to add your own labels in VP annotations to do this... Quote Link to comment
