1,189 -
Calendar
Everything posted by JuanP
Reporting the issue to our web team - thank you for reporting it.
The following are real-world system requirements for running Vectorworks 2023. In some demanding cases, we would suggest a more capable machine than is described in these hardware profiles. Likewise, there are some less demanding situations where Vectorworks will perform well on older hardware. General Requirements Operating Systems macOS 12 (Monterey) macOS 11 (Big Sur) Windows 11 Windows 10 64-bit Recommended Hardware Profiles High-end Profile: For large projects, complex and very detailed models/drawings, complex renderings (such as large BIM projects, large entertainment venues, commercial sites, GIS, high-end landscaping design, photorealistic rendering) Processor: 3.0+ GHz Intel Core i7 or AMD Ryzen 7 with eight cores, or better Apple M1 Max or higher RAM: 32GB or more Graphics Card: macOS M-series: M1 Max 32GB or higher macOS Intel: Metal GPUFamily2 or later, 8GB VRAM or more Windows: DirectX 11 compatible, 8GB VRAM or more 64GB Unified Memory (M-series) / 12GB VRAM or more is recommended when using multiple displays, or a 4K or higher resolution display. Vision requires a dedicated OpenGL 4.1 compatible graphics card with 8GB of VRAM or more, preferably released in the past three years (e.g. NVIDIA GeForce RTX 2080 TI series, AMD Radeon RX 5000 series). Display Resolution: 1920 x 1080 or higher Hard Disk: 10GB of free disk space is required for the installation. 30GB or more is required for a full installation with all libraries. Case-sensitive file system volumes are not supported. Installing Vectorworks on flash storage (SSD) is recommended. Mid-level Profile: For medium-sized projects, complex models/drawings with a medium level of details (such as small commercial projects, mid-size entertainment venues, residential site modeling) Processor: 2.0+ GHz Intel Core i7 or AMD Ryzen 7 with six cores, or better Apple M1 Pro or higher RAM: 16GB or more Graphics Card: macOS M-series: M1 Pro 16GB or higher macOS Intel: Metal GPUFamily1 v4 or later, 4GB VRAM or more Windows: DirectX 11 compatible, 4GB VRAM or more 32GB Unified Memory (M-series) / 8GB VRAM or more is recommended when using multiple displays, or a 4K or higher resolution display. Vision requires a dedicated OpenGL 4.1 compatible graphics card with 4GB or VRAM or more, preferably released in the past three years (e.g. NVIDIA GeForce RTX 2070 series, AMD Radeon RX Vega series). Display Resolution: 1920 x 1080 or higher Hard Disk: 10GB of free disk space is required for the installation. 30GB or more is required for a full installation with all libraries. Case-sensitive file system volumes are not supported. Installing Vectorworks on flash storage (SSD) is recommended. Minimum Hardware Profile Entry-level Profile: For small projects, simple models/drawings with a low level of detail, simple renderings (such as small residential projects, small theaters, small landscaping design) Processor: Intel Core i5 or AMD Ryzen 5, or better Apple M1 or higher RAM: 8GB or more Apple M1 and later Macs share memory for general processing and graphics. We recommend more memory for these systems than for traditional systems where RAM and VRAM are separate. Graphics Card: macOS M-series: M1 8GB or higher macOS Intel: Metal GPUFamily1 or later, 2GB VRAM or more Windows: DirectX 11 compatible, 2GB VRAM or more 16GB Unified Memory (M-series) / 4GB VRAM or more is recommended when using multiple displays, or a 4K or higher resolution display. Some integrated graphics cards such as Intel Iris Plus/Pro/Xe series are acceptable for very simple models/drawings, but a dedicated graphics card is preferable. Vision requires a dedicated OpenGL 4.1 compatible graphics card with 2GB of VRAM or more, preferably released in the past three years (e.g. NVIDIA GeForce RTX 2060 series, AMD Radeon RX 500 series). Display Resolution: 1440 x 900 or higher Hard Disk: 10GB of free disk space is required for the installation. 30GB or more is required for a full installation with all libraries. Case-sensitive file system volumes are not supported. Hardware Requirements for Project Sharing Server Operating Systems: Windows Server 2012 or later Windows 11 Windows 10 64-bit Note: Installation of the Microsoft Visual C++ Redistributable package for Visual Studio 2017 is required. Some Windows systems will already have this installed. If not yet installed, the installation files can be downloaded from the Microsoft Visual C Downloads page. macOS 12 (Monterey) macOS 11 (Big Sur) macOS 10.15 (Catalina) macOS 10.14 (Mojave) macOS 10.13 (High Sierra) macOS 10.12 (Sierra) Note: Project Sharing Server can also be installed on any system that supports Docker such as Network-Attached Storage (NAS) devices. Processor: 64-bit Intel Core 2 Duo or better RAM: 4GB or more Hard Drive: A flash storage (SSD) is recommended. Case-sensitive file system volumes are not supported. Network Requirements for Project Sharing Project sharing requires high-speed network connections. As the network bandwidth increases, so does project sharing performance. Slower network speeds can still provide a satisfactory user experience if you minimize operations that transfer large amounts of data over the network (such as committing changes to the project file or refreshing a local working file). Server-based LAN Sharing: Minimum: A Fast Ethernet (100Mbit/s) network connection with minimum 50Mbit/s on upload. Recommended: A Gigabit Ethernet (1Gbit/s) network connection is required for large projects. Firewalls should allow network ports used by the Project Sharing Server. The default port is 22001. It is configurable during installation. The network must support HTTP 1.1 standard. Server-based LAN Sharing is the recommended method of sharing for teams on the same LAN. File-based LAN Sharing: Minimum: A Fast Ethernet (100Mbit/s) network connection Recommended: A Gigabit Ethernet (1Gbit/s) network connection is required for large projects. Cloud Sharing: Project sharing using cloud-based storage requires a high-speed internet connection (50Mbit/s or above). This method of sharing works best with small teams or small projects. It is not recommended for large teams or large projects. You can expect significant speed improvements when using Dropbox with LAN sync enabled. Vectorworks Cloud Services and/or Dropbox are the preferred cloud-based sharing solutions for project sharing. Hard Drive: Storing project files on flash storage (SSD) is recommended. Hardware Requirements for Site Protection Server (network license manager) Operating Systems: Windows Server 2008 R2 SP1 or later Windows 11 Windows 10 64-bit macOS 12 (Monterey) macOS 11 (Big Sur) macOS 10.15 (Catalina) macOS 10.14 (Mojave) macOS 10.13 (High Sierra) Processor: 64-bit Intel Core 2 Duo or better RAM: 4GB or more Hard Drive: 30MB free disk space is required for installation. Case-sensitive file system volumes are not supported. Redshift System Requirements “Redshift by Maxon” render style employs the computer’s GPU and CPU to perform photorealistic rendering. The following system requirements relate specifically to this render style. Redshift will use the computer’s GPU for rendering if it meets the following requirements. If the GPU does not meet the following requirements, only the computer’s CPU will be used to perform Redshift rendering. A message shown in the Edit Render Style resource dialog box denotes when Redshift is available or not available. When Redshift is chosen but not available, Custom Renderworks render style is used instead. Minimum Requirements for Redshift using CPU only macOS: Apple macOS 11.5 (Big Sur) or later Windows: 64-bit Windows 10 macOS M-series: Apple M1 16 GB Windows: 8 GB of RAM Processor with SSE2 support (Pentium 4 or better) macOS Intel: 8 GB of RAM Minimum Requirements for Redshift using GPU macOS M-series: Apple M1 16 GB Windows: 8 GB RAM NVIDIA GPU with CUDA compute capability 5.0 or higher (https://developer.nvidia.com/cuda-gpus) and 8 GB VRAM macOS Intel: 8 GB RAM AMD "Navi" or "Vega" GPU or later and 8 GB VRAM See supported AMD GPU list below Single GPU Recommended Requirements for Redshift using GPU macOS M-series: Apple M1 Max 32 GB or better Windows: 16 GB of RAM or more Core i7 or Xeon equivalent, 3.0GHz or better NVIDIA GPU with CUDA compute capability 7.0 or higher (https://developer.nvidia.com/cuda-gpus) and 8 GB of VRAM or more macOS Intel: 16 GB of RAM or more AMD "Navi" or "Vega" GPU or later and 8 GB VRAM or more See supported AMD GPU list below Multiple GPUs macOS: List of supported AMD GPUs for Redshift MacBook Pro Radeon Pro Vega 16/20 Radeon Pro 5500M/5600M iMac Radeon Pro Vega 48 Radeon Pro 5500XT/5700/5700XT iMac Pro Radeon Pro Vega 56/64 MacPro Radeon Pro Vega II / Vega II Duo Radeon Pro W5500X/W5700X Radeon RX 6800/6800XT/6900XT Radeon W6800X MPX Thunderbolt eGPUs Radeon RX Vega 56/64 Radeon Pro WX 9100 Radeon VII Radeon RX 5500/5500XT/5600XT/5700/5700XT Radeon RX 6800/6800XT/6900XT Radeon W6800X MPX See this document for more information about macOS compatibility of specific GPUs Additional Details Graphics Cards IMPORTANT – Several Vectorworks features have placed higher demands on graphic hardware. Additionally, the performance and quality of the graphics provided by the Vectorworks Graphics Module depend directly on the speed, memory, and supported extensions of the graphics card. These features have the potential to provide a very fast and fluid experience if used on capable hardware, or a noticeably slower experience if used on older or incompatible hardware. Graphics cards should support at a minimum macOS Metal GPUFamily1 and Windows DirectX 11; cards not meeting this recommendation will not work. In general, the more powerful your graphics card is, the better your Vectorworks experience will be. For the latest information on our graphics card recommendations and for other hardware recommendations, go to the Quality-Tested Hardware page. We strongly recommend that all users check that their video drivers are current. The majority of display problems reported to our Technical Support department have been traced to older video drivers. In general, a recent graphics card running the latest drivers is preferable to an old high-end graphics card running outdated drivers. Windows users should install the latest video drivers from their card vendor’s web site, especially for new PCs and after installing Windows OS updates. MacOS users should use the latest stable version of macOS available (non-beta), as macOS includes ongoing fixes for video drivers. From our testing, Metal drivers in old macOS versions may show serious issues on certain specific video hardware; after updating to the latest macOS the same hardware performed well and without issues. Similarly, minor version updates may improve stability; graphics problems seen on certain hardware on macOS 10.15.1 were resolved simply by upgrading to macOS 10.15.7. For these reasons we recommend using the latest macOS with your system. How to find macOS Metal version: You can view the graphics hardware information by choosing About This Mac -> System Report… -> Graphics/Displays. On laptops with more than one GPU, the System Report will show the less powerful “integrated” video GPU then the more powerful “discrete” video GPU. Metal compatibility is listed as: “Metal: Supported, feature set macOS GPUFamily1 v4”, meaning this hardware can be described as “GPUFamily1 v4". VRAM: The amount of Video RAM (VRAM) required to drive Vectorworks adequately depends largely on the size of the display being used and the complexity of the Vectorworks document. When using multiple displays or high resolution displays, more VRAM are required to keep the same smoothness with the same file. Using Multiple View Panes with different visibilities in all panes can be VRAM-intensive in large Vectorworks documents. Rendering of shadows and edges are VRAM-intensive. If you want to take full advantage of shadows and edges, especially in situations where you have any combination of the following: many lights point lights image textures anti-aliasing high shadow quality excessive geometry And if you have a graphics card with minimum specifications, you should consider upgrading your graphics card. M-series and Unified Memory: Apple M1 and later Macs share memory for general processing and graphics. We recommend more memory for these systems than for traditional systems where RAM and VRAM are separate. Vision requires a dedicated OpenGL 4.1 compatible graphics card, preferably released in the past three years. We do not recommend any integrated Intel video chipset. While Vision may run under these environments, we do not support them due to their lack of performance and speed. We recommend gaming cards over workstation cards for Vision due to the higher clock speed. Vectorworks may be used in conjunction with real-time rendering engines which have their own demanding hardware requirements. For example see Lumion. Remote and Virtualized Environments Vectorworks runs successfully within remote and virtualized environments. We are confident that offices that wish to operate using virtualization technologies will have success with this option, if the software is given adequate resources comparable to the desktop system requirements listed elsewhere in this document. Offices must develop IT in-house or contract out IT support for their chosen virtualization system. Vectorworks Inc. can only provide general guidance, since many virtualization options exist, and every virtualization technology has its own details realized uniquely for each office. Vectorworks is a graphical application and as such requires high quality graphics support from the virtualization technology chosen. The graphics recommendations listed in the system requirements for desktop operation are a good guide for what is necessary for virtualized GPUs. The virtualized copies of Vectorworks must have sufficient graphical support to operate successfully. High network bandwidth and low network system latency are also critical for acceptable user experience when using Vectorworks in virtualized environments. Maintenance Releases Unless there is a known problem with a maintenance release of the operating system, we recommend the latest maintenance release at the time we ship a new release of Vectorworks as a minimum because that is what we test with. If you have problems with an earlier maintenance release, we will often ask you to update as an initial troubleshooting step. Optimizing Performance For users who work with large files and complex renderings, we recommend running with at least 32GB of RAM. When RAM runs out, Vectorworks usually continues to function, but is slowed significantly by the need to access the hard drive to provide virtual memory. Extreme lack of RAM may cause operations to generate errors in cases where given sufficient RAM they would otherwise succeed. Faster hard drives can have a large impact on system performance especially when virtual memory is actively being used. Several tasks in Vectorworks leverage multiple CPU cores. Faster or slower processor clock speeds also have a predictable impact on Vectorworks performance. Hard drive size requirements are driven by the total size of Vectorworks including all content files. You can reduce this size by opting to not install some of the larger Vectorworks content files. Project Sharing and Network Bandwidth The performance of Vectorworks when working on a shared project over the network will depend on the available network bandwidth. If the network bandwidth is insufficient, operations that transfer large amount of data over the network will be slow. We recommend at minimum a Fast Ethernet (100Mbit/s) network connection. For large projects, a Gigabit Ethernet (1Gbit/s) network is required for a fast and fluid experience. Project sharing using cloud-based storages requires a high-speed internet connection (50Mbit/s or above). This method of sharing works best with small teams or small projects. It is not recommended for large teams or large projects. You can expect significant speed improvements when using Dropbox with LAN sync enabled. Vectorworks Cloud Services and/or Dropbox are the preferred cloud-based sharing solutions for project sharing. Although project sharing requires high-speed network connections in general, slower network speeds can still provide a satisfactory user experience if you minimize operations that transfer large amounts of data over the network (such as committing changes to the project file or refreshing a local working file). Examples of data transfer times during commit and refresh operations for different bandwidths and project file sizes are shown in the chart below.
@Tom W. What the repair does is for every file in the Vectorworks installation you have, it will verify that it exists and compare a MD5 hash of the file with what the hash should be. If a file is missing or has different contents (hashes don't match) then it will repair the file by downloading the correct file and copying it in place of the missing or changed file. "Change Version" does the same thing as repair, but instead of the version you have (the value stored in VWVersion.txt), it uses the version you pick and repairs using that. I hope that helps.
You are a public speaker that enjoys teaching and training the latest software to designers in your industry. You have a passion for design and or computer graphics. You have proven presentation skills and principles for learning and instructional design. You are looking for the opportunity to teach the latest trends and best practices in a client facing environment. Vectorworks, Inc. is looking for a product trainer that will be responsible for delivering hands-on training courses both online and in person for local and virtual User’s groups. The trainer will be expected to quickly grasp and apply all of the design disciplines for the Vectorworks product line. Location: United States Schedule: remote or onsite and 50% travel Compensation: DOE Steps: Apply here If you meet the requirements, a member of our talent acquisition team will contact you! Questions: recruiting@vectorworks.net
Vectorworks and Vision 2022 Service Pack 4 Available for Download
JuanP commented on JuanP's article in Tech Bulletins
Could you send me file for testing? Also, would you mind sharing your computer specs? thanks -
Vectorworks abandoning perpetual licences
JuanP replied to line-weight's topic in General Discussion
@P Retondo We have been preparing and investing for this change. Currently, we have three new tech support specialists finishing their training and getting ready to help all our customers, and we are hiring one more for our UK office. -
Additionally, the subscription offering will be enhanced to include all the same premium benefits of Vectorworks Service Select at no additional cost. This means that when you subscribe to Vectorworks, you have access to additional product library content, exclusive training, more Cloud Service storage, and cloud rendering. We will send an email mid-September with instructions on how to access the new Service Select benefits. -
Bug: Refreshing Lighting Instrument Summary Resets Perspective Crop
JuanP replied to Mike Wood's question in Troubleshooting
You can send it to jalmansa@vectorworks.net Thanks -
@D4ry4n87 Please contact uktech@vectorworks.net for additional support. We will be able to help you.
@MartinFahrer Is this happening with multiple DWG files? Can you share some for testing? If you can't post the files to the public, email me at jalmansa@vectorworks.net.
Please let us know. Since yesterday, I've been getting some customers reporting that 12.5 seems to have fixed the issue. However, it is too early to tell.
how can you show shadows in hidden line rendering as shown below?
JuanP replied to mike11968's topic in Architecture
The Heliodon tool is part of the Visualization Tool Set palette and you can find it in any of the Design series products of Vectorworks, Architect, Landmark, Spotlight and Design Suite. Unfortunately, it is not part of Fundamentals. -
Vw 2013 re-install -- how to find full serial number
JuanP replied to JHEarcht3's topic in General Discussion
You can contact us at tech@vectorworks.net with that info, and we can provide you with the complete serial number. -
Hi All, thank you for your patience while we follow up on this issue. We have had similar reports with a Mac Studio/Studio Display. However, we are still gathering information to identify the cause of the problem. Next time you experience a crash, if you can note the time when it happens and send us the whole "Macintosh HD/Library/Logs" and "Macintosh HD/Users/Library/Logs" folders. That will be helpful. jalmansa@vectorworks.net Thanks,
@Andy Broomell I think this is what is happening. I looked into this, but Title it's hard coded in the forum - submitting a wish to the developer for a possible change to to "topic name," as it has been suggested. Lately, more people have forgotten to add the Vectorworks version and the computer specs as part of their signature. There is a way to make this mandatory, any concerns? For those who have not completed the profile, they will see the following: Let me know what you think.
@Jack2022 We support only the last released version, i.e. VW2022 exports Revit 2022 files. Revit itself does not support export to a specific version and ODA libraries work in identical way. Can you share privately the RVT file provided to the consultant for testing? - thanks
@frankyV5You can post here: https://forum.vectorworks.net/index.php?/forum/13-entertainment/
@Sade Instructions here
- 1 reply
- 1
@Jaz It will help if you share the iMacs' specs and MacOS. Also, make sure the latest SP4 is installed. Thanks
@MHBrown We just released Vectorworks 2022SP4, I suggest you updating Vectorworks, and if the problem persists, feel free to contact me directly at jalmansa@vectorworks.net and I'll be happy to connect you with one of our support specialist to check your files or see if there is anything else we can do. It would be ideal if you could provide as part of your signature, computer specs, and operating system.
Schematic Views cannot be Pasted without the Model Object they are Based On
JuanP replied to pfalvi's question in Troubleshooting
2022 SP4 is live now for all non-localized English versions
