Content Count
97 -
Calendar
Everything posted by Allen Brown
Here you go, actually 2014: .
Just received a new MacBook Air and of course immediately installed Vectorworks 2021 SP2. I've had no issues so far except turning off Ambient Occlusion in an OpenGL sheet viewport. Speed seems faster than my 2014 MacBook Pro..
Never mind, forgot to check the pallet and activate. 🙂
I'm having an intermittent issue selecting colors from a vendor pallet, say Sherwin-Williams. Usually I'm unable to select but once in awhile it works. No problem selecting from the standard color palletes. Anyone else and is there a fix? I'm using an iMac Pro with trackpad, latest Catalina, and both VW 2020 and 2021 with the same results..
Just installed 2021 on both Macs running the latest Catalina update and started having a problem selecting from a list such as a color or model from a manufacturer or catalog. Exported back to 2020 with same results. Any similar experience?
2020 Architect Open GL Rendering ...
Allen Brown replied to Allen Brown's question in Troubleshooting
Here's the download workaround just in case.. VPDuplicatesSetPref.vwx -
Autorotate not working in Renderworks v2020
Allen Brown replied to Allen Brown's topic in Architecture
The issue is the image prop will “face the camera” in open gl but not renderworks. -
My results on the test file for all renderworks modes are no autorotation. -
Thanks for confirming, I also tried some native tree objects with the same result.. -
Using v2020, image props autorotate in Open GL but not Renderworks, worked fine in 2019. I've attached a sample file and screenshots of each. Anyone have a fix? Image Prop.vwx
Thanks, it worked!
Trying to create a concrete panel model with a recess with an elliptical curved fillet. I was able to create the main part of the panel with an extrusion. Tried to create a profile and path for the curved top which worked but then can't add to the main panel through solid addition. Any ideas? I've attached the vectorwork file as well as a PDF of the model. panel.pdf panel.vwx
Haven’t tried it yet but noticed the problem viewport was duplicated to the right when toggling settings. Because if the patch name, must have something to do with that. -
Same experience. -
(Like the dark mode!)
I'm using the same iMac Pro as well as a 2014 MacBook Pro. Downloaded 2020 yesterday and so far have few issues (that I've posted in Troubleshooting). All have occured on the iMac Pro but not on the laptop. I might try upgrading to Catalina on the laptop when its released to test..
... on sheet layer viewport, unchecking Use Colors in Background Render works intermittently in Mac Mojave 10.14.6.
... is not working on Mac Mojave 10.14.6
Well. I’ve never had software requiring such a lengthy beta. Is there not a developer period to correct bugs? And wasn’t 64k known for quite awhile? One more thing: what about OpenGL / Metal?
Elevations and depth of field
Allen Brown replied to AlanW's question in Wishlist - Feature and Content Requests
Just found this topic. I second the motion! Hope this feature is in 2019.. -
I never checked Renderworks, thanks! I'll report it as a bug..
Here's an example file with a wall on a design layer and two viewports of the wall on a second design layer. You can see any texture change to the wall is reflected in the viewports and that you can override visibility and turn the wall on and off in the viewports but you can't change the texture of the wall in the viewports. example.vwx
Yes, I've checked all the settings, and again as suggested. In the OIP Viewport settings, I can turn classes off and on for different elements but changing a class texture has no effect.
I've created a house design viewport that I've placed multiple times on a site plan layer in the same document. I can change class visibility of each viewport to modify the design but not class textures. Also tried creating multiple viewports of the house design in a separate site plan file, same issue. I'd like to vary colors, textures etc by house. Any ideas?
