TeeMuki
54 -
Reputation
6 NeutralPersonal Information
Location
Finland
Recent Profile Visitors
Attribute Matching Tool Not Allowing Hardscape "Main Joint Pattern" to be Edited
TeeMuki replied to gloudon's question in Troubleshooting
Thank you! The same bug seems to be also in Vectorworks 2026.3- 5 replies
- attribute mapping
- hardscape
(and 1 more)
Tagged with:
Yes, i have been struggling also with this. It stopped working in Vectorworks 2025 at some point between updates... @Katarina Ollikainen Is this an aknowledged bug, this needs really to be fixed asap. The workaround trough OIP Joint Pattern Angle is not really streamlined 😄 Thank you!- 5 replies
- attribute mapping
- hardscape
(and 1 more)
Tagged with:
Hi, i've experienced the same thing when using the Vectorworks 2025 Survey Point Tool and using there the "selection" lock survey point... It is not a selection, but you will know what i mean when you open the Survey Point Settings via Object Info.
New Landscape Area interface not working with 2D graphics
TeeMuki replied to Jonk's topic in Site Design
@Katarina Ollikainen, in update 4 it is now working 🙂 One huge improvement to our offices use, would be if the Landscape areas Plant Line could follow the Landscape areas border as it is. So if my Landscape area is the red line shown, it would be so nice to be able to set the Plant Line to go with the border. So basically we would like to have move attributes to be set inside the Landscape areas, like in Hardscape areas. Our client is demanding us to combine 3 different classes into one object, when we produce a dwg for them. Class 1. Edge/Border line Class 2. Fill Class 3. Hatch With Hardscape tool it is possible, but for now it is not possible with Landscape areas. As Landscape area objects General Class i use the Class 1. Edge/Border line. As Landscape area objects 2D Bed Area i use the Class 2. Fill. And because the Plant Line / Plant Cloud is not producing line as the object it self i can't use it as the Class 3. Hatch. Only workaround is that i combine the Class 3. Hatch into Class 1 or Class 2, but this is not really what we want to do. Somehow i would imagine that this would be a rather easy task to add to the tool. @Katarina Ollikainen What do you think, is this possible to add to the Tool? Until that our workflow is to use Landscape area with Classes 1 & 2, and then use 2D Polygon Tools Inner Boundary mode to create the hatch on top of it as a separate object... -
JFC Landscape areas make me want to tear my damn hair out.
TeeMuki replied to DSmith2300's topic in Site Design
this caught my eye, what is the schedule for releasing this update? 💪🏻 -
Sorry for updating this late, but we did proceed with the workflow of grouping the symbol and the 2 stake objects. It worked well for our needs. Thank you for your help!
After trying out i found maybe the settings i am setting wrong... But does some one know what is the difference between these two ways, and why is not the first working, and should it work as i expect? Way 1: Setting 2D Attributes for bed areas via Landscape Area Style. -I was assuming that since i have set for the selected class the fill style, choosing Fill: Class Style would give the object the same fill as i have set for the class. This way this is not working for me. Way 2: Setting 2D Attributes for bed areas via Landscape Area Style. -choosing Fill: Solid and then for the Solid Color the Color By Class selection gives me the right colour as a fill ( the same colour as i have set for the class). I think this is a little confusing, but it is working after all... So can someone explain why the way 1 is not working? and the right way to do this is by way 2? Thank you! -
Our client is demanding certain graphic attributes for the objects. And our whole office has to use the same graphic attributes for the objects, so it would be best to set the attributes via classes to Landscape areas and as well to other objects, so that we can produce visually alike material trough out our office. -
Vectorworks 2025 Update 3, still having some issues with Landscape areas 2D graphics 😞 Class Fill When defining to Landscape areas 2D Bed area Attribute the same class and selecting Make all attributes by class The Landscape area has this weird dark green colour When defining to Landscape areas 2D Bed area Attribute the same fill colour manually it has the right 2D graphic Outcome When i ungroup the Landscape area with the incorrect 2D graphics it gives me these objects. When i select the 2D Bed Area fill class and select the Make All Attributes by Class, it changes the colour to the correct one, so i assume my class settings are right. The problem is in the Landscape Area Attributes. -
@Jonk Thank you for your quick response! I did not phrase my words right, is it possible to get the plant line to be a "basic" line, not with that sawtoothy linetype? For our demand the line has to be same for border line, hatch and fill. So as far as i know the basic plant line/cloud is not a solution for us sadly 😞 -
Hello, Since the Hardscape Tool got an overhaul, i would really like to see same possibilities of controlling the Landscape areas Attributes. After trying different ways of setting Landscape areas, i can pretty surely say that this outcome is not possible? The Landscape areas class itself doesn't seem to make any difference to the appearance nor the components of the object. While in the Hardscape objects, the class itself will be a part of the component when decomposing/ungrouping the object. So i achieve this in Hardscape objects by: -General class = Class border -Attributes, Base Fill = Class fill -Attributes, Joint Pattern Overlay = Class hatch Has anyone a solution to this, how to achieve the wanted outcome with Landscape areas? If there is no way to do this with 3 different classes in a Landscape area object, is it even possible with 2 classes? Because i can combine the hatch and border or hatch and fill if needed... The plant line is almost doing the trick (as working for the objects border line), but i need the line to be excactly as the object. So is there a way to change the linetype of the plant line? Thank you for your help! -
Thank you for your fast response. I'll share the files with you via PM.
Maybe this problem has the same rootproblem as in this post below: https://forum.vectorworks.net/index.php?/topic/92129-color-palette-migration-to-vw2022-change-colors/
Hmm, the problem actually still exists for our whole office. When we open a new blank file in Vectorworks 2025 the colors are working, but when we open files that have started in Vectorworks 2024 the colors are not working. This problem is now atleast on 5 different computers and licences... Now i did open up a new blank file in Vectorworks 2024 and the colors are working, but on our projectfiles they are not working... Below again one example Blank file opened in Vwx 2024/2025 colors are correct The same rectangles copied to our projectfiles (opened in Vwx 2024/2025) looks like this What can cause this? Is there a way to set up some colormodels (RGB/CMYK etc..) for the project, because it seems like this would be a simplified colormodel... Does the import dwg maybe somehow change this colormodel to a simplified one? Please help, this is actually a big problem for our office right now...
I did some quick try with Vectorworks 2025 update 2, and this seems to be fixed in the current version... Would be nice to have this fixed also in the 2024 version, but this might not be possible?
