I am trying to look up values in another worksheet where it contains all the information.
As a test, I have typed in the same formula as shown in the Vectorworks example, however nothing is happening...
Function example (copied from vectorworks)
=XLookup(value, [use_pattern], not_found_value, array_lookup, array_result)
Find a value in the array_lookup, and return the value from the array_result at the found row. the arrays should be ranges on the same column.
Parameters:
value - the value that will be searched in 'array_lookup' (a range defined in a single column).
use_pattern - use regular expression pattern for the search.
not_found_value - the result if 'value' is not found
array_lookup - a range defined in a single column to search the 'value' in
array_result - a range defined in a single column to to provide the result from the row that the 'value' was found in 'array_lookup'
=XLookup('tech', 'not found', 'Worksheet-Values':A1..A3, 'Worksheet-Result':B1..B3)
Named worksheet: 'Worksheet-Values':
| A
1 | support
2 | tech
3 | PR
Named worksheet: 'Worksheet-Result':
| A | B
1 | 1234 | support@vectorworks.net
2 | 1235 | tech@vectorworks.net
3 | 1236 | PR@vectorworks.net
