Hans-Olav
682 -
Posts posted by Hans-Olav
There are some videos in the help section, her for example:
Hi
If its the objects you are after "old style layer referencing" is an option, you can pick the layers you want to include. Afterwards if you delete the reference you get an option to keep the layers.
- 2
What if you choose the long option? will it then appear?
If you have the serial number I guess you should be able to get a new copy from Nemetchek
Hi
Not sure it is corrupted, I think you need an old computer with old OS to run it.
here is some info:
Preset themes for auto-color options is a good idea!
On 1/15/2019 at 1:37 PM, mike m oz said:
This is a vw file
The excample file in this tread (Jan 15) looks similar to the one in service select. Why not use it?
Hi
If you create a sheetlayer and make a viewport with your view, you will be able to assign a renderworks render to the background view and a line render to the foreground view .
I would have tried custom renderworks instead of final, usually the highest settings is unnecessary and just adds rendering time.
- 1
Hi
I haven't tried in a while but think its kept in the Resource browser in your file, after you run the custom naming command .
Some info from help:
To create a custom naming standard by worksheet:
1. In a new file, select File > Document Settings > Standard Naming.
The Standard Naming dialog box opens.
2. Without making any changes, click OK.
Three worksheets are created in the file, and are visible in the Resource Manager: ClassNameStds, LayerNameStds, and ViewNameStds.
3. From the Resource Manager, right-click one of the worksheets and select Open from the context menu.
The worksheet opens for editing.
Highlight column D (User 1) and from the Worksheet menu select Insert > Columns. A new column is added in front of the selected one.
New columns must be inserted after the AIA/NCS column and before the Description or Pen Color column.
4. Enter a name in cell D1 for the new standard.
5. Enter a new standard name for each cell below D1.
Cells left blank in the ClassNameStds worksheet will be assigned to the “None” class. Cells left blank in the LayerNameStds worksheet will be assigned to the “Layer-None” layer. Blank cells are not permitted in the ViewNameStds worksheet; if a worksheet with blank viewport/view names is attempted for use in Standard Naming, an error message is displayed.
6. The new standard is displayed in the Standard Naming dialog box.
To use these changes in other files, either save the file as a template to be used as the basis for new drawings, or import each worksheet into the other file before running the Standard Naming command.
I just went over to
https://portal.productboard.com/7pu88c9kpmqtzt8hwg6arujh/tabs/5-in-progress
and submitted a request for direct link between VW and TM. I think its a good idea and hope more people will do the same!
- 2
Hi
I have found that increasing the simplification tollerance of sitemodifiers helps improving the speed without decresing the visual. My document is set up in meters and having the simplification tolerans to 0,1 is ok
rotate = 5 is for rotating objects
rightclick and drag is rotate view
this is posible to customize in preference I think. Not in front of TM at the moment.
- 1
I'm not sure. I guess 3D mesh is the best option. Sometimes I have had luck with "add solids" prior to cutting but it depends how the geometry has been made.
- 1
It looks like a curtain wall or a curved wall with window. I don't understand why you not are able to select it . Would you mind sharing the file, I can take a look?
- 1
can you send a screenshot of the unwanted object?
If you assigned a class to your door tag (ID TAG) when you made the symbol you can turn off the class. Otherwise you have to edit each symbol and turn it off or assign a class to the tag.
Another approach is to use door styles and set up a style with class controlled tags
If you make all classes and layers visible, can it then be seen?
You can change the text size and font with the regular text menu and also turn on and off the tag with the object info palette
Curved retaining wall site modifier causing issue
in Troubleshooting
Posted
Hi
I did a test here and adjusted the Simplification Tolerance for the site modifier to 5" and it is not that bad to update
