P Bartoli
153 -
Reputation
1 NeutralPersonal Information
Occupation
designer
Homepage
www.bartolidesign.it
Location
Monza, Italy
Recent Profile Visitors
VW Architect 2020 licenses WANTED
P Bartoli replied to P Bartoli's topic in Buying and Selling Vectorworks Licenses
Hello David, the VW 2020 licenses are still on sale ? -
Hello, due to Covid lockdown, I'm moving one of my VW 2018 Architect licenses from Mac to Windows. Problem is I can't find the Windows installer file link for downloading what should be something like "'Vectorworks2018-SP2-401138-SeriesE-installer-win". I searched in the download section https://www.vectorworks.net/support/downloads, but seems like they're not available... any help ? Thanks !
What about VW 2018 ? Does it work with Catalina ?
Thanks Boh !
Is it possible to select and delete duplicated items in VW 2018? I suspect that in a drawing I've received from a suppliers, many items in the drawing are duplicated one on the other. Can I select duplicated items ? I don't see this possibility in Custom Selection tool... can I do it?
I'm working with VW Architect 2018 international edition, that comes with its default libraries. Talking about screws AFAIK the supplied library contains screws and bolts in Imperial units only. Is it available a ISO metric library as well ? Where can I find it?
I'm experiencing an unexpected behavior of the the Fillet tool. Working in 2D Plan view, I try to fillet two lines and apparently nothing happens. By trial and error, I've found that, if I switch to Orthogonal (view), or else zoom the view in or out, the fillet magically appears... but: - the fillet is not selectable/editable in 2D Plan, but... - if I switch to Ortogonal, I can edit the fillet, and switching back to 2D Plan the fillet is now selectable/editable. BTW, I'd like to understand better how Planes work. I noticed that in the Object window, my lines are by default placed on the "3D" Plane, but I have also the opportunity to switch to "Screen" Plane. If, before performing Fillet tool operation, I move my lines to Screen Plane, everything works as I'd expect, without problems. Therefore my question is: how can I set by default to work on the Screen Plan instead of the 3D Plane? Thanks!
probably found the answer... convert to group ?
I'm new to VW 3d... would like to transform a viewport featuring a front view of a 3d object into a 2D editable "front view" drawing. Can Viewports be transformed in editable 2d drawing entities ? Can I do this ? Thanks
Selling Vectorworks licenses
P Bartoli replied to simon.norman's topic in Buying and Selling Vectorworks Licenses
Hi simon, you can email the details at paolo@bartolidesign.it, thanks -
Still on sale ? How much do you quote and which kind (Fundamental or Architect?) Thanks -
exchanging files with Autocad DWG... and back into VW
P Bartoli posted a question in Troubleshooting
I will shortly need to extensively exchange VW drawing files with partners working with Autocad, back and forth. I've been for years using VW and sending DWG file to clients, what I usually do is send both a DWG and PDF file, to be sure that they understand and read my drawings correctly. But I didn't need to get back the same drawing into VW again... I would like to hear your advices about the best way to organize my VW drawings and the best exchange options to use when exporting and importing DWG. I know VW drawings structure are quite different from DWG: - in VW I use often layers with different scales (1:1, 1:50, etc). How can I manage this in DWG? - styles and thickness. I'd like to keep the same look in VW and DWG files since I will be going back and forth from VW to DWG and back to VW. How to achieve the best compromise? All contributions will be welcome... Thanks -
I'm looking for a VW license. Anyone selling an old copy of Vectorworks? Thanks
5 Designer/Renderworks 2011 Licenses For Sale
P Bartoli replied to BenP's topic in General Discussion
Hello Ben, do you still have some VW 2011 licenses to sell ?
