Ari Phillips
    17
Everything posted by Ari Phillips
  1. @Donna_savage @Greg Wood Sorry for the late reply. I have one license left. Let me know if your interested. You can contact me at ari@nugget-design.co.uk Kind regards Ari
  2. @GyanaB Hi Gyana If your still interested , Drop me an email at ari@nugget-design.co.uk and i can run through it all with you. Kind regards Ari
  3. Hi David, Send me an email to ari@nugget-design.co.uk and i can update you if your still interested. Kind regards Ari
  4. @Freddy Hey, Thanks for your interest. I sent you an email. Kind regards Ari
  5. @n_studio Hi Lizzie, Are you still looking for vectorworks? I have 1 spare version if Vectorworks 2020 Architect / Renderworks that im not currently using And would like to sell it if you are still interested? Ari
  6. Hi I have 1 spare version if Vectorworks 2020 Architect / Renderworks that im not currently using And would like to sell it if you are still interested? Ari
  7. Hi alL I also have 1 spare version if Vectorworks 2020 Architect / Renderworks that im not currently using And would like to sell it if you or anyone here is still interested? Ari
  8. Hey All. It may sound a little silly but i dont tend to use the many options there are for the wall tool and usually just use the standard default wall tool for drawing. I had a play around with it this afternoon to explore drawing curtain walls and other exterior walls and now there is no way to get it back to the default unstyled wall to draw as it was when you first get it? Is there any way to re set the wall tool to the default original setting so it can be editable with the parametric data in object info, has the 3d element and the line weights are not all over the place? Seriously confused. Also i used to be able to click Shift to constrain an object along an axis when moving it. but now it seems to duplicate it? Any idea how to change this? Thank you : Kind regards Ari
  9. Hi Jeremy, Thanks for you reply. Im actually using the latest version of Vectorworks so not sure this would be the problem. Siri Is off. Spacebar does work to pan, but it doesn't work when used with the space bar, command and alt keys. Looks like i may need ti review the user folder..will look into that, although looks like there may be other better ways for such shortcuts now...is it that thee keys are not supported as much any more? I tend to use them as they are the same on all the above software and seems to keep things streamlined as easy..less confusing when jumping from software to software. Could possibly be im still using a 2015 model laptop? Maybe its time to upgrade too. Thanks for the feedback. Will kept you posted Kind regards Ari
  10. Spacebar, Command, Option no longer zooming in or out and really slowing down my work flow. I rely on this hugely to work fast and efficiently. Any ideas. Its not safari as i dont have it open...and dont seem to have any other conflict. I used: Spacebar - Pan Spacebar , Command to zoom in Spacebar, Command, Option to zoom out. This was what i was always using but found it only worked on some workstations.... I have upgraded to Mojav an also my wacom tablet to the latest intuos and wondered if this would be the problem, however i am desperate to find a solution so i am able to use these hotkeys again. Please help...its frustrating not being able to use something when you have spent years and years using it that way..feel a little lost. Please help Thanks Ari
  11. Spacebar, Command, Option no longer zooming in or out and really slowing down my work flow. I rely on this hugely to work fast and efficiently. Any ideas. Its not safari as i dont have it open...and dont seem to have any other conflict. I used: Spacebar - Pan Spacebar , Command to zoom in Spacebar, Command, Option to zoom out. This was what i was always using but found it only worked on some workstations.... I have upgraded to Mojav an also my wacom tablet to the latest intuos and wondered if this would be the problem, however i am desperate to find a solution so i am able to use these hotkeys again. Please help...its frustrating not being able to use something when you have spent years and years using it that way..feel a little lost. Please help Thanks Ari
  12. @Hans-Olav @Pat Stanford Thank you both for your help and input. Thats most helpful indeed. Kind regards Ari
  13. Thank you @Hans-Olav That worked by converting to unstyled. Although not entirely sure what this means? Should e always do this? What happens when the sheet is converted to unstyled? What impact does this have on anything else? Also what does it mean by " do you want to load the currently opened files along with the active file too? I font understand why i would want to open other opened files for editing the sheet ? If i say yes, would it amend all sheets with this border style? Thanks so much 🙂 Ari
  14. Hi there, We are currently struggling to change the amount of 'most recent revisions shown on the drawing'. There once was a time we could control how many would show, and we could have the last 3 for instance...however this option appears to be greyed out now And we have no idea how to change this? Is someone able to advise? Thanks Ari
  15. Hi Pat, thank you for answering, however from what I understand you can create hybrid models and objects to show as 3D objects in 3D space such as in perspective views etc. But if you want to show the same object in a plan or elevation it shows as simply 2D objects which I have created in the component editor. The issue is these only show in plan view and not in elevations as they are supposed to. I can go into the hybrid object and generate 2D from 3D component in each view, such as front, back and side (thinking this will save time in elevations) but when I come to the viewport or front view it still shows as a faceted 3D model. The only time I want a 3D model in view is in 3D space. Dies that make it any clearer? Have I completely miss understood? thanks Ari ps another quick question...is there also a way to convert a section viewport elevation taken from a clip cube to a editable drawing? Rather than linking with the model? As sometimes we do a rough model to create the basic space and add detail after. Used to be able to do this with sections etc however the clip cube is brilliant and would be great to use this also. Thanks. Ari
  16. Hi there, Having major issues getting any of the 2d components of a 3d symbol hybrid object to show up. I have followed the basic tutorial and all seems fine until you exit the symbol and then it only shows as a 2d object in plan but not in the other views, such as front or side view. Any ideas how to resolve this please? Thanks Ari
