Ari Phillips
21 -
Reputation
2 NeutralPersonal Information
Location
United Kingdom
Recent Profile Visitors
Thanks, Not entirely sure abut the issues myself as it was also doing this on vw 2021. Will keep using it for a bit and see what happens. Thanks Ari
Thanks @jeff-prince Odd indeed. I didn't actually upgrade my hardware at all. I bought it this spec...just reset it back to factory settings. Will have to see how I go Thanks for trying Kind regards Ari
HI Jeff, Thanks for this. This would be my normal checks, however the issue is even with the simplest of files? As I have reinstalled all software again incl Vectorworks I don t have any plugins linked as yet and its still slow. Even with flat graphics and no 3d models. I haven't dared opening any complex drawings as yet as its already having issues. Is there any way within the Mac I can allocate more ram or speed to the application? Thanks Ari Do you have items far from the origin? No. Have you created some plug in objects with bad behavior? - New installation, No plug ins Did you move this file from a previous version of vectorworks into 2022? I have tried with new and older files Do you have a site model with bad and/or big data in it? Not currently working on any 3d models
Hi there, I have had issues with the speed of vectorworks of late. Almost a year now. I thought it was potentially my machine so at the beginning of the year I purchased a new super spec Mac. I was sure this would speed things up...however it still runs painfully slow. I get the spinning wheel after almost every action and painfully slow when navigating between annotations, crops and design layers. I even completely deleted my machine and reset it back to factory settings and re imported all software back as new and its still slow. Is there anything I can do to speed up the software or allocate more ram to the application? Its driving me insane and really not very efficient at all. Especially when you have to wait between every action. Hope someone is able to advise. My comp spec is MacBook Pro (16-inch, 2019) 2.4 GHz 8-Core Intel Core i9 64 GB 2667 MHz DDR4 AMD Radeon Pro 5600M 8 GB Im running Vectorworks 2022 on Mac OS Montery I look forward to hearing some solutions. Thanks so very much Ari
Looking for VW architect for Mac
Ari Phillips replied to Vaskene's topic in Buying and Selling Vectorworks Licenses
@GyanaB Hi Gyana If your still interested , Drop me an email at ari@nugget-design.co.uk and i can run through it all with you. Kind regards Ari -
Hi I have 1 spare version if Vectorworks 2020 Architect / Renderworks that im not currently using And would like to sell it if you are still interested? Ari -
Hey All. It may sound a little silly but i dont tend to use the many options there are for the wall tool and usually just use the standard default wall tool for drawing. I had a play around with it this afternoon to explore drawing curtain walls and other exterior walls and now there is no way to get it back to the default unstyled wall to draw as it was when you first get it? Is there any way to re set the wall tool to the default original setting so it can be editable with the parametric data in object info, has the 3d element and the line weights are not all over the place? Seriously confused. Also i used to be able to click Shift to constrain an object along an axis when moving it. but now it seems to duplicate it? Any idea how to change this? Thank you : Kind regards Ari
Spacebar, Command, Option no longer zooming in or out
Ari Phillips replied to Ari Phillips's question in Troubleshooting
Hi Jeremy, Thanks for you reply. Im actually using the latest version of Vectorworks so not sure this would be the problem. Siri Is off. Spacebar does work to pan, but it doesn't work when used with the space bar, command and alt keys. Looks like i may need ti review the user folder..will look into that, although looks like there may be other better ways for such shortcuts now...is it that thee keys are not supported as much any more? I tend to use them as they are the same on all the above software and seems to keep things streamlined as easy..less confusing when jumping from software to software. Could possibly be im still using a 2015 model laptop? Maybe its time to upgrade too. Thanks for the feedback. Will kept you posted Kind regards Ari -
Ari Phillips posted a question in Troubleshooting
Spacebar, Command, Option no longer zooming in or out and really slowing down my work flow. I rely on this hugely to work fast and efficiently. Any ideas. Its not safari as i dont have it open...and dont seem to have any other conflict. I used: Spacebar - Pan Spacebar , Command to zoom in Spacebar, Command, Option to zoom out. This was what i was always using but found it only worked on some workstations.... I have upgraded to Mojav an also my wacom tablet to the latest intuos and wondered if this would be the problem, however i am desperate to find a solution so i am able to use these hotkeys again. Please help...its frustrating not being able to use something when you have spent years and years using it that way..feel a little lost. Please help Thanks Ari -
