31 -
Reputation
0 NeutralPersonal Information
Occupation
Landscape Architect
Location
Germany
Recent Profile Visitors
1,451 profile views
Hello everyone, we have here a problem with a Customer that uses iMac 24'' M1, he says that the pallets appear empty / gray after starting Vectorworks and the position / size of the pallets are not saved. Anyone had / has this same problem? Does anyone knows about such happening? Thank you in advance.
3D solid Import from AutoCAD
António da Cunha replied to António da Cunha's topic in Solids Modeling
Thats a pretty nice and clean job that you did there! Thank you. But it is a pity that Vectorworks does not import the file properly as it should. With SketchUp the file is imported with 3D solids and not just lines (NURBS). -
Thank you to both of you for the help given. I really appreciate it. 🙂 -
There it is. Thank you. Stairs.dwg -
Hello, I have stairs created with AutoCAD, which is a 3D volume (solid). Imported to Vectorworks and they appear as NURBS inside a Group. I'm not able to convert the NURBS to a generic Solid. Is there a possibility to have this 3D import as a Solid in Vectorworks and not NURBS? Thank you in advance!
Yes. That is what I was looking for. Thank you! I found that exact same document about 40 minutes ago, but your added explanation makes everything much better. Thank you, Jim!
Hello, I need a link where Vectorworks says that Oculus Rift and other variants are supported. I've been searching for such and can't find. Is there some place where Vectorworks states that? If yes, please provide me the link. I really need that. Thank you!
Export Image maximum size?
António da Cunha replied to António da Cunha's topic in General Discussion
Its a Viewport of a Park, with around 221 x 244 meters at 72 DPS and my MAC has 16 GB RAM. Edit: 221 x 244 meters. Means I am trying to export it at 1:1 scale as an image. If its dependent on RAM, that makes sense and already cleared my question. I really thank you for that, Good Sir. -
Hello, What is the maximum size to export a Viewport as Image? Pixels? Width? Height? Can I have a specific number? I get this message: "Could not export image due to invalid size of width or height."
Hello, What could be the reason for the Remote QR-Code not appearing (blank) and when clicking on "Start Server" VW crashing? Broken Plug-in? Firewall blocking? ...something else? Thank you!
Is it possible to influence the order of Layers and classes when exporting 3D PDF? I have an order of Layers 01, 02, 03, etc... and I want them to be exported in that order as a 3D PDF and stay in that order when opening my PDF viewer. Is this possible? Right now they stay in a disorganised order. Thank you!
Export Import DWG Problems - General questions
It worked. Youre great! Thank you so much! I am happy that such a simple command solves the situation and above all that is not a problem from Vectorworks! Thank you!!
