Shibli79
  • Content Count
    12
Community Reputation
0 Neutral
About Shibli79
  • Rank
    Greenhorn
Personal Information
  • Location
    Malaysia
  1. Shibli79
    Disappearing Title Block
    Hi All, I am using VWX 2018 and yup this problem still exist. Once i close and reopen my files title block is not visible, only the borders are.What i did was select the title block and move 0,0 and it will appear again. Goes well too is you double click title block for editting, move by nudge etc. as long you do some operation on the title block it will appear again.Just imagine if i have hundreds of sheets. Hopefully VWX will find a solution for it. Thanks,
  2. Shibli79
    Export To IFC
    Hi, I opened the ifc file in revit & the grid line does not appear, only levels are in the ifc file. I export using 2x2 & 2x3 ifc format. Tried also to link in revit using ifc 4 format. But still does not appear. Its ok, i am just curious if there is other user facing the same issue and found the solution. Btw, i am both revit & vwx user. :-)
  3. Shibli79
    Export To IFC
    Hi elepp, Thanks for the option but i still cant export grids & propertyline to IFC format. I downloaded the sample file in the tread given but it use combination of lines,text to make the grids but i use grid tool for mine & property line tool. the grid lines are assign to ifcgridaxis similar in the sample file. but still no luck on it. Thanks anyway.
  4. Shibli79
    Export To IFC
    Hi, First of all I am a beginner in Vectorworks 2018. Sorry if my question have been resolved before but I could not find the related tread in this forum. Just a simple one. I am working with consultant that used Revit. How can I include my property line & grid line to exported IFC format. I need to pass this setting out for them to follow.I found out that levels will follow when I create the stories. Can anyone help me? Thanks,
  5. Shibli79
    Property line object segments annotation
    Hi, I am upgrading from VWX 2D conventional use to VWX architects since I need to comply with BIM requirement to any current project. So I am really beginner to this workflow. I wonder is there any options to add prefix or suffix onto the property line segments annotation. In my country, what we are practicing now is despite the distance & bearings to be shown along the property line we used to annotate it according to its uses. Ex: boundary line. building setback line, basement setback line etc. As of now I will just put a text for it. Just wonder... Thanks.
  6. Shibli79
    CUSTOM SCHEDULES
    Thanks for the reply Pat. Will look into it.
  7. Shibli79
    CUSTOM SCHEDULES
    Hi Jonathan, Thanks for the reply but i know i can do that in a normal worksheets. But can i do this in the door schedule with the preset format? But i will get that tutorial manual.
  8. Shibli79
    CUSTOM SCHEDULES
    Hi there, Can i customise my schedule format from the upper image to the lower image. Please refer image attached. I have tried to make a custom schedule but it will still come out as per default schedule by vectorworks. Thanks.
  9. Shibli79
    Multi storey building set up
    Hi there, Need some advice on multi storey building file setup. I am modelling an apartment. in 2d it is easy to manage a unit of the apartment by using symbol since it is typical. but how should i do it in 3d model for BIM purposes. I have no clue at all.
  10. Shibli79
    Coordination With Other Consultants
    Thanks for your advice. Will there be any data lost either model from VW or Revit since my other consultants are using Revit.
  11. Hi there, I am new to Vectorworks BIM. Is there any feature similar to clash detection in Revit in VW? Or i need to export it to IFC object and need a 3rd-party software to run the test. TQ.
  12. Shibli79
    Wall Join Problem
    Hi, i'm using VW2010/2013 architect version. i'm having problem to join walls because it took a long time. my file is not that big (42mb). when i worked using fundamental version it is fine but the problem occur only in architect version. is there any setting for wall tools in architect version to solve this? thanks.
