TKA
244 -
Everything posted by TKA
I World like to know what settings you have, I followed instructions and I have to redo palette settings every morning. Even when I use just the big screen the palettes loose position.
I found a way around it, when applying tag directly with data tool it has a problem because of the size of the label itself relative to the window, if I put the label next to the window and then drag the leader over there is no problem. However, it doesn't make sense why windows which are outside of the section cut be an active choice in that section.
I am trying to tag windows in elevation and for some reason tag tool highlights windows on the back elevations, they are bigger. I tried elevation and limited section both the same. Is there a way to toggle overlapping items?
I made more tests and I can't find what is the reason for some objects being "invisible" to data tag. I sent it to the tech support.
I am using single object mode and this particular tag doesn't see the record of invisible object, if I make the object visible in the view port the tag recognizes it and attaches itself, when I go back and turn it invisible the data tag still is attached to the object.
here is the test tag, it seems to have lost the ability to tag the invisible objects. It worked before and other tags work regardless whether object is visible or not.TAG test.vwx
I have different data tags attached to different objects some visible some invisible. I has been working faultlessly, then suddenly linking to invisible objects stopped working, the links work when connected to visible and then turned invisible objects and maintain data feed. Other tags still work - are linking to invisible objects. I was searching through settings but cannot find what governs this.
maybe something doubles the count, can you "control" click on line one and "sect item" and then repeat for line 2, is it coming up with the same object/title block?
To delete, or not to delete VW Backup files, that is the question:
TKA replied to Mark Aceto's topic in General Discussion
I keep 1. backup of every major issue/revision. 2. current file on VW auto save. 3. time machine which I found the most useful. once project is signed off i remove #1 while keeping pdf of it. the only time I needed to go back was always time machine, I would say in the last 10 years. Though I might be lucky only twice I had a corrupt file I had to replace. -
thanks, I will follow the thread
I got my data tags mostly under control. there are two things I could not find online help with: 1. What exactly is a multiple attachment points, what does it serve and how do you invoke it? 2. Is it possible to harvest twi different types of data, Bayonne line is a #area# and another is #Window#.#ClearArea#. From what I experimented with it all has come from one source, so what I am looking for is a tag that responds to A or B and not A and B.
yes, depending where is the data coming from, the issue here is that if you use static text the flipping will occur, I managed using record formats to add prefix in the formula - data tag layout (unstyled), edit dynamic text/tag field, pick the record formula than add in front of it what would be otherwise in static text. Once that is done then tag works with horizontal auto positioning.
Vectorworks Revit Export is better than Revit's IFC import!
TKA replied to shorter's topic in General Discussion
unusable, I have been avoiding it at all costs. -
Data tag is not accessing all available stair object parameters. It would be great to have stair data displayed at he right size in different scale viewports (just like window and door tags). It is strange though that for instance in simple stair I can get R&T size and fl to fl, not the number of risers though, in new stair tool only fl to fl and a lot of other parameters which I doubt anyone uses. Seems like an unfinished project with stair tool (again).
thanks, it is strange though that for instance in simple stair I can get R&T size and fl to fl, not the number of risers though, in new stair tool only fl to fl and a lot of other parameters which I doubt anyone uses. Seems like an unfinished project with stair tool (again). I will post it in the wish list.
Data tag is not accessing all available object parameters, in this case stair. 2020 has some and 2021 has even less parameters listed, is this on purpose? or should all stair parameters be accessible in the data tag?
just to reframe this: Data tag is not accessing all available object parameters, in this case stair. 2020 has some and 2021 has even less parameters listed, is this on purpose? or should all stair parameters be accessible in the data tag?
I am trying to create stair data tag to overcome the viewport scale problem with standard stair data in design layer. I am having trouble finding right object parameters in pull down menus inside the data tag - I am looking under Object Parameters for Rand Size, total run(this I found) markers UP & DN, simple stuff and I just cant find it, so I wonder if that requires writing a script?
thanks, I checked my settings and they are exactly like the one you suggested.
if anyone can advise: 1. I know a lot of people use laptops and additional big screens. I have a MBP 15" and additionally 27" screens. Even though I save palette position if I open VW on just MBP and then back on the big screen it never goes back to saved position. Same palettes but congested/overlapping. 2. Quite often when reopening the VW the palettes are also just a tiny bit off with some overlap. In both cases they appear shifted up as if the screen was a bit smaller. I guess I could keep two workspaces but then I need to remember saving changes to both of them.
I have a line type made up of two parallel lines and circles (LED tape), when it is a single line or a closed polygon it displays correctly, however, an open polygon (which is the 99% case on my drawings) results in a flipped condition, see below.
may be your right click is not set up right, try using keyboard, I am on OSX so its 'control' +click, I think. its something similar on windows.Once you click you have to have the resource window open or activated with rollover.
I am having issues with wall end caps, I tried adjusting with allotting I know and I can't figure out what is wrong. I have included image of what is happening, I can connect wall without a problem. The image shows 3 images of the same wall type with exactly the same settings. I color coded different layers of the wall to better see what is happening. Additionally it looks like there are some inconsistencies for no reason - I used end cap tool exactly the same way on all of them. The blue and red are outer and inner finishes, the line thickness is set to thin, but shows as thick, I solved the problem by setting line thickness to NONE, but why is this happening?
- wall
- extra lines
(and 1 more)
Tagged with:
never mind, I had a invisible object causing it.
- 4 replies
- wall
- components
(and 2 more)
Tagged with:
here is a mystery bounding box highlighted in red as I move cursor above it, its actual 6" tall and it affects the tile spacing
- 4 replies
- wall
- components
(and 2 more)
Tagged with:
