HEengineering
478 -
Posts posted by HEengineering
a bit off topic, but Id like to see an example of what is being discussed. Sounds interesting(the rendering part)! We usually render in VW, but also use PS supplementally. I always find it interesting to see the wide array of approaches.
Awesome. We will give that a shot. Not sure how it became active, maybe a mis key, or its possible user error. Ill give this a go. This board is such an amazing tool. I have never seen support like this anywhere else.
Im not surprised to see it related to the none class. We usually try not to put objects on this class but early on it can be a bit sloppy. Would have taken me years to find that.
sure can Matt., see attached.
I haven't been able to replicate it. I tried reproducing the parts to no avail. Tried multiple difference rendering settings with no luck either. We've done many others with success, this particular one was a real challenge.
Please note the cabinet has some extracted faces to accept a transparency texture for the graphics. Im sure there is room for improvement here.
Also Im aware that the photos are less than Ideal, and in some instances we don't have really good perspective lines either. Im at the mercy of schedules and this is what I have been provided and have to work with.
I guess I just want to know what's causing it so if It comes up again we know what to look for. Im starting to wonder if the camera match aspect in this particular file didn't get corrupt or confused.
Open GL seems to lessen it, but were trying to render them all with the same level of consistency if possible. Appreciate you looking into it for us!
Im having this exact same issue. Specifically only happens in custom render style not open GL. I do not have any site modifiers tho?
Im using VW 2017 with camera match and Im not sure I noticed this in prior renderings but were in the midst of doing 100s of these and this something that keeps showing up. Any thoughts? Outline in the render style is turned off.
This is rendered with High anti alias and high in the curved geometry as well. DPI is over 300. What am I missing here? @Matt Panzer
How many cores can rendering use? Im talking Imac pro vs Imac
We are testing a new imac pro, and while it seems to perform excellent Im wondering if a standard 27" with top of the line graphics and processor wouldnt be a better bang for the buck. We are looking at adding 2 more machines regardless and at the IMac pro price point it begs the question.
I also recall many saying VW can take advantage of the multi core in the macs? We are moving into more renders, and i some instances more DTM's. Maybe after more time with the Imac Pro I will see the up side? I just want to get some outside opionions on others maybe more familiar with the hardware side of things. If we can run a standard Imac fully spec'd I see no reason to go crazy spending on Imac Pros, as much as Id love to have em!
FYI I mac pro is the 27" stock option.
Thinking @zoomer and @jimwilson can shed some light maybe? Any others feel free to chime in.
We keep our work group library on the server.
Even if Im already in to the sever and the work group path is set thru VW prefrences, I still have to physically navigate to that folder on the server every morning or VW will not see it?? I can hit refresh, but that will not work if I don't navigate to the folder thru the finder window first.
Silly but is really annoying. Why am I setting a path if VW needs a little push to find it every morning.🤨
I also echo Jeremy's comments above regarding folder structure. I have the same gripe, Why must I click into 3 subfolders before I can get to what I want. These little things add up and cause frustration at times.
You're right on that account as well. I'm fumbling thru this a bit, but none the less mission accomplished👍
I got It. Sorry Pat. Now I see what you were saying. The path for that file thru the attributes not only has to maintain the file naming convention but the path as well. A little counterintuitive until I read it thru a few more times.
Thanks for the help guys!
I actually took the file and put it in the users default, and then named accordingly. It now shows up in user under the attributes panel, but Im looking for it to show under workgroup.
What I was missing was that the file name has to be xxxx_Default Line Types.
The alais Idea sounds ideal, great suggestion. Now last step is getting under workgroups in attributes pallet. I already have it in the Resource Library as u can see above.
Anyone else had luck testing the vertex tool? Or the swale. I wanted to create a swale near a already modified area, and while I was close to the modifier, I was not interfering with it.
The VW Help Manual states that any of the surface tools should not overlap and existing modifier. It seems not only can they not intersect or overlap, it seems that can't even be in the same proximity.
For example I can draw a swale away from any site modifier and it comes out as expected. Get within 10' of a road with a boundary or a pad or any modfier, either the swale action fails upon exit, or it shows up all funky and distorted?
My hope was I could use the swale tool along a road if needed for water runoff.
Vertex tool wont even activate. Spent 2 days testing and never got the tool to even function.🤨
Ill give these a look Pat thanks! My belief here is there is no advantage over say a favorite?
Forgive me all. I just found zoomers write up on this. Forgot you needed to have these files residing in a folder called "libraries"
Can anyone tell me how I can get files to show in the workgroup library as opposed to say adding a favorite? We currently just use favorites, but wondered if we could be overlooking advantages.
Its not clear to me via the Kbase and I would like some clarification
I have set a desired location to look for work group folders in the VW preferences? But I don't see those files come in thru the browser? Maybe Im misunderstanding how this works??
I can confirm that SP2 on 2019 does seem to fix the visibility issue between proposed and existing contours.
However Im now experimenting with the swale and berm tool along with the add vertex. One thing Im noticing is when you choose to edit the site model surface and you try to activate add vertex, the button activates and then deactivates. As if its completely broken?? nothing activates in the mode buttons either.
In addition the swale tool seems to show one thing when editing, then when exiting that mode back out to the DTM It may or may not even show up. Seems like some of the new features are still "new". Maybe some others have had better sucess, I am working from a model originally designed in 2017 which I guess could present some issues, tho shouldn't. But thats another story.
Im also wondering the same here. While I like what VW has built in I often wonder if Artlantis or C4D would speed up workflow in the long run maybe for specialty projects? Most of our renders are often conceptual and subject to a municipality review. I could see down the line the city wanting more detail and more photo realistic renders in some situations.
While Renderworks is great. At times I feel like I have to limit size and quality so render times don't run wild. Seems like maybe these programs render in real time or much faster from what I gathered?
@Jim Wilson File is to big for email. Can I DM it to tech or best to send to you thru the forum?
@Jim Wilson It appears the SP2 for 19 has come closer to resolving this issue as the contours appear to be showing correctly now with the working terrain model I had been testing with.
The big hang up now is when I try to make even the smallest change to the model, its taking close to 5 minutes(no exaggeration) to update, which is wayy to long. My computer should be up to the task? If this is normal then I would say this is still a unusable feature?
where as the same file in 17 updates within 30 seconds or so. Any thoughts? I did try other models in both 17 and only encountered slow update times with 19.
Hmmm, I just tried testing 2 site model that were completed in 17 and tried to open and test with 19. Both seemed to have locked up VW19 SP2 after several attempts. Guess Ill try a reboot?
Looking at the SP1.1 update for 2019 and I notice landmark gets site model updates? Did architect get these updates as well?
Landmark:
Site Model - Multiple corrections to sculpting interface and graphical appearance
Plant Catalog - Corrected an problem related to deleting plants from a custom catalog
Foliage - Fixed an issue that caused the tool to be unusable on certain hardware configurations
Plants - Corrected a plant graphic issue tied to using Best Performance graphics
Landscape Area - Stability improvements
Site Model - Site Model from Boundary should now display it’s tooltip as expected
Renderworks - is it worth the effort
in Rendering
Posted
if no post production why in the PSD file format?
