3,173 -
Posts posted by Andy Broomell
1 hour ago, Pat Stanford said:1 hour ago, Andy Broomell said:
Is there something in the code preventing this?
The other way around Andy, its not that there is something in the code preventing it working in Symbols, it is that there is nothing in the code specifically handling being in a symbol def.
Or the other way other way around... the thing that's IN the code is the ABSENCE of the code specifically handling being in a symbol def 🤣😉
37 minutes ago, Boh said:
I have noticed that in vw 2023 the make all attributes by class button turns the class line markers on. Previous versions didn’t do this.
See this thread: https://forum.vectorworks.net/index.php?/topic/92650-vw2022-line-endpoint-style-always-visible-when-make-all-attributes-by-class/
And maybe this one: https://forum.vectorworks.net/index.php?/topic/92770-2022-class-marker-style-no-none/
Apparently it's still not fixed on Windows, according to some users? Working correctly for me on Mac...
- 1
Hi @Pat Stanford!
I use this script all the time with a keyboard shortcut (Cmd+Y) and it's immensely helpful. Saves me a lot of time, thank you!
However, it seems to not work in certain contexts. For example, I don't think it works when editing inside of a Symbol. Is there something in the code preventing this? -
Are you given a warning of some sort, or does nothing happen?
When you make a new class, make sure to take a look at these two dropdowns which determine the visibility of the new class.
That being said, this dropdown defaults to Invisible (at least at the beginning of each Vectorworks session?), and I too wish it defaulted to Visible.
On a related topic... when you copy and paste objects into a file, any classes that are brought along default to being invisible in existing Saved Views and Viewports. There's no setting or warning about this. You have to manually go fix it by right clicking the class in the Nav palette and choosing Visibilities. I wish this operation also defaulted to Visible.
- Popular Post
- Popular Post
I do wish there were a way to force delete a color swatch (and replace it with another, like with can with symbols, classes, etc).
- 6
In addition to Tom's comment, remember colors are used in additional places, such as... Textures, RW Backgrounds, Hatches, Tiles, Class Attributes (including hidden colors saved for attribute types that aren't the selected type), viewport overrides, Layer colors, Data Vis, Worksheet text, etc.
- 3
- Popular Post
- Popular Post
Hi all! (I hope it's okay to post this here.) For those who don't know me, I'm a Set Designer & Art Director working in the TV & Film industry in Los Angeles. This Saturday, November 19th, I'll be teaching a live-online Vectorworks class demonstrating how to use Data Visualization to automatically recolor a model based on data of your choosing. In my example below, the bottom elevation is color-coded by department (such as Construction vs Graphics vs VFX) and this was done using Data Visualization. If you'd like to learn more, click the link below and hit the RSVP button!
https://www.andybroomell.com/masterclass-data-visualization
The class is open to all and will be held via Zoom, starting at 10a Pacific on 11/19 and finishing within two hours. It’s free to join, and if you end up enjoying the class you can pay-what-you-will via Venmo or Zelle.
Thanks, and I hope to see you there!
More info: https://www.andybroomell.com/masterclass-data-visualization
[Note: this is not an official Vectorworks-sponsored class, just something I'm doing on my own.]
- 4
- 1
I assume when you say "click render" you mean "click export."
But regardless, that's very strange; it means that the process of exporting the PDF is not delivering what's already on the page, because if you uncheck the "Update visible out-of-date viewports" checkbox, then no rendering processes should happen as you save the PDF. It should save what's there.
Next thing I'd try is to see whether there's a difference between File > Export PDF, vs File > Publish, vs Printing to PDF driver if you have that on your machine.
At the end of they day I'd maybe resort to Mark's suggestion of screengrabs (or maybe File > Export > Export Image File > Each page as separate page?)
Good luck!
- 1
Out of curiosity, are the viewports re-rendering during the process of exporting the PDF?
I tend to uncheck this box to avoid re-rendering (assuming I've already made sure my viewports 'look' up to date, even if they're technically not):
Regardless, this bug shouldn't be happening, but curious if this changes anything.
- 3
14 minutes ago, E|FA said:
As far as I remember, I have never received a quick confirmation with a ticket number that a support request was received.
Same. Although I stopped using the bug submit form in 2020, prior to that I had submitted multiple bugs and never once received an automated email confirmation (though I think there's a 'confirmation' directly on the page after you hit submit). In the end I only received emails back about a couple of the issues, and only one issue (regarding software activation) was resolved successfully.
- 1
On 1/14/2021 at 9:40 AM, jeff prince said:
As a customer, I do not recall ever being asked of my opinion on the utility of having Rhino/Vectorworks connectivity.
Same.
@JuanP - In the film industry, the three software packages that are most commonly used for set design drafting are SketchUp, Vectorworks, and Rhino. It's common for an art department to have a mix of folks each working in their program of choice simultaneously. We often have to reference each other's work, or even completely take over projects started by someone else despite working in different software.
I'm not familiar with what "Rhino.Inside" has to offer specifically, but having better Rhino connectivity would be AWESOME for set designers. And when it comes to importing, Rhino and SketchUp should ideally have just as much granular control as DWG has.
- 4
Since locus points might cause unintended changes to the Title Bock, another option would be putting in a Rectangle and setting both the Pen & Fill to None, so nothing prints but there's still snappable geometry there.
- 3
Indeed, it seems there should be a way to import palettes of other filetypes into Vectorworks.
After a cursory glance into Photoshop, it looks like I can export a folder of swatches as an .aco filetype, which is presumably an Adobe thing (I wonder how closed off / proprietary it might be?). If external palettes could be brought into Vectorworks via a command that could be a useful workflow improvement.
Essentially the Color Palette Manager window needs an "import" button:
- 2
I 100% agree that the simple ability to offset the trim would incredibly helpful. (And of course, eventually being able to use custom profiles as well).
I think this has always been possible, unless I'm not fully understanding the context of your post.
You should be able to drop in .xml files into your User Folder > Libraries > Defaults > Color Palettes.
That being said, I have no idea if these .xml files are coded/formatted in any sort of standard way or if they're Vectorworks-specific. My only custom palettes are ones I created in Vectorworks, so perhaps your wish for a more robust "Import" command is well-wished for.
Do you have an example of a color palette from another software that you could upload here?
- 1
I feel like that should be a red message in the status bar at the bottom of the screen.
VE-103603
- 3
4 hours ago, Tom W. said:
The one small complaint here is that in a grid view you only get the name after hovering over the colour for what feels like a long time whereas before it appeared instantaneously in the box above
This has started to irk me as well.
- 4
100% agree that the slider colors are sorely missed.
- 2
No changes that I'm aware of in 2023.
- 2
Both of Kevin's comments are 100% spot on.
- 1
I'm just happy this sort of complex criteria is now possible at all, being able to mix AND & OR criteria at will. Prior to 2022(?) it wasn't even a possibility.
- 3
I think it should look more like this:
You have to be very precise with the 'nesting' which is indicated by the alignment of the criteria.
- 4
Agreed. Currently this can be done per-viewport for SECTION viewports, but cannot be done for regular viewports. In addition to the lack of functionality, the inconsistency is bothersome.
- 2
Make all attributes by class
in General Discussion
Posted
Seems to be working so far! You're a lifesaver as always.
