Retaining Wall Site Modifier - Bug #2 ? - Edge hook
Another Retaining Wall Site Modifier quirk:
Create the modifier from a Round (arc) source wall via AEC>Terrain>Create Retaining Wall Site Modifier.
Edit the z value at center or end of Left/Right Retaining edges via Reshape tool.
Result is a hook, or added short vertical (nearly) segment at the new position.
This hook does not have an editable vertex.
But it does cause a crease in the site model surface.
Strangely, no hooks at start edge if those vertices are moved.
In the image, the End edge is hidden for clarity.
-B
