I am several months into working with Vectorworks Landmark 2022. I have just completed a first 2D landscape design on an imported DWG base plan. Everything has gone well and I have recently developed 4 sheets with a variety of viewports and imported an imported spread sheet. When I went to export or publish the viewports, only two of the 4 exported successfully as PDFs. The other two froze and crashed my iMac. I ended up printing them to PDFs instead of exporting or publishing them.
Now I am to the stage of exporting a DWG for the Architect to use to finalize the plan. I cannot export in any of several formats I have tried (DWG, DWF, PDF, etc.). It always freezes at an object very late in the process (somewhere around 7720 of 7760 objects. The program crashes and has to be force quit. I have let it sit for an hour with no resolution.
I can export another simpler drawing I am used as a tutorial. It was an imported DWG that I modified as well.
I am working in OS 12.4 Monterey on a late 2015 iMac with plenty of RAM but just standard vRAM. I have also tried the process using the same file on a more recent M1 iMac running Monterey and has the same experience.Any help with this is welcome. Deadlines are approaching.
Curtwitt
Hello all,
5 answers to this question
