tbone Posted May 14, 2022 Share Posted May 14, 2022 Hello i need some help to filter something out of a list of x,y positions. I want for example the point [10] in the list and get the responding x,y positions. I'm to confused at the moemnt to do it.😅 Creating the grid in a rectangle for testing is no problem but then filtering it... grid.vwx Quote Link to comment
Pat Stanford Posted May 14, 2022 Share Posted May 14, 2022 Since you are using the Student version of VW, most of us will not be able to open your file. Â Can you post a screenshot of your network instead? 1 Quote Link to comment
DomC Posted May 16, 2022 Share Posted May 16, 2022 Hi You can use the "Get Item" to get an element of a list. Input 0 to get first Item. So 10th Item you get with input 9. Â 2 Quote Link to comment
tbone Posted May 17, 2022 Author Share Posted May 17, 2022 On 5/16/2022 at 8:13 AM, DomC said: Hi You can use the "Get Item" to get an element of a list. Input 0 to get first Item. So 10th Item you get with input 9.  I done it right all the time but it needed to be an integer as an input but i did a number😅 Small thing that makes a huge differents the "number to integer" On 5/14/2022 at 10:01 PM, Pat Stanford said: Since you are using the Student version of VW, most of us will not be able to open your file.  Can you post a screenshot of your network instead? 1 Quote Link to comment
