bhorowitz Posted July 5, 2000 Share Posted July 5, 2000 I'm using the Theatrical Lighting.sta for the first time for a large lighting plot. I've been a Minicad user for many years. I've gone through all the steps to place data labels where I want them and to create instruments. My question is this; When I define a symbol from the 'lights' folder as an instrument, all the attached data that was with the symbol(inst. type, wattage, beam angle) goes away. Am I doing something wrong? Also, is it possible to use different label layouts for different symbols? Thanks, Bud Horowitz Quote Link to comment
Guest Frank Brault Posted July 6, 2000 Share Posted July 6, 2000 Hi Bud, Kevin mentioned that he answered this for you in the other list, but just so that anyone reading through this, who needs the answer, gets it, here goes: From the Theatrical Lighting Readers List: > There is a problem with one of the files that shipped with > VW 8.52 that is > keeping record information from being copied from the lighting > symbol to the > lighting instrument. The lighting instrument is a group with its record > attached to the outside of the group. All of the instrument info is still > attached to the symbol that is inside the group. When you use the > instrument insertion tool, or convert a symbol into an instrument we take > your symbol, figure out where it is and where all the labels need > to go and > then group it all together and place the instrument info in a > record that is > attached to this newly created group. > > In response to your second question about label styles. It is not > currently possible to define more than one label legend and choose which > instruments use which legend. You can have multiple label styles in a > document by cheating a little though. > Once you have your plot basically done, you can go back and > change the > label legend and selectively update instrument labels from these legends. > As an example, lets say you want to have all of your VL-5s display only > their channel and unit numbers, and not the dimmer field that the rest of > your instruments are using. Switch to the setup labels sheet and change > the label formatting to what you want to use for your VL-5s. > Switch back to > your light plot and select all of the VL-5s in the document. You > might want > to try the custom selection tool as a quick way to do this (Pg 18-3 of the > VW Manual). From the Theatrical Lighting menu, select instrument > processing, and then Update Labels from Legend. This will update all > selected instruments to use the new legend. You can continue > doing this for > your other instrument types. Existing instruments will not automatically > change to use the new legend information, so you can take > advantage of this > "feature" to have multiple sets of label styles. > > We are currently developing a new lighting design product > which will have > more advanced tools for lighting designers. Some of the features of this > new product will be the ability to have multiple label legends in a > document, the ability to assign a label legend to a particular > instrument or > type of instrument, and also geometric containers for labels. You will be > able to have channel circles, dimmer hexagons or whatever, they are user > definable. So if you like to have 8pointed stars as the > container for unit > numbers of source 4s and red ovals around color labels for cyc > lights you'll > be able to do this quickly and easily. > > > Kevin Moore btw, these files are now available at: http://www.nemetschek.net/downloads/vectorworks/index.html There is a Mac .sit and Windows .zip available for download. Detailed instructions for installation are included in the archive. hth, Frank Brault Quote Link to comment
