André Galvão Posted May 10, 2022 Share Posted May 10, 2022 I'm not having trouble in quantify fixtures outside the toilet stall, but inside, the worksheet doesn't find the fixtures. Quote Link to comment
Pat Stanford Posted May 10, 2022 Share Posted May 10, 2022 Do you have the INSYMBOL box checked as part of the criteria? If that is not not it, can you post a simple file with a few fixtures inside of stalls and outside of stalls and the worksheet you want them to display in? Quote Link to comment
André Galvão Posted May 10, 2022 Author Share Posted May 10, 2022 Yes, i checked the box in criteria. I have attached a file with the spreadsheet I am using. If you could look, I'd really appreciate it! Quantify Fixtures inside Toilet Stall.vwx Quote Link to comment
Popular Post Pat Stanford Posted May 10, 2022 Popular Post Share Posted May 10, 2022 It appears to be the Include Subparts that is the the problem. If you uncheck that then I get the 7 fixtures you are expecting. Based on the worksheet help, it appears that Subparts only apply to high level objects like Walls. In this case you only need the Plugin Objects check box since that will allow you access to the symbols in the Toilet Stall. HTH 5 Quote Link to comment
André Galvão Posted May 10, 2022 Author Share Posted May 10, 2022 @Pat Stanford Incredible! Thank you very much! You solved my problem perfectly! 2 Quote Link to comment
