LEAFS Posted February 18, 2006 Share Posted February 18, 2006 I am adding a plug-in to Vectorworks. I have installed it in the plug-in directory. I made a additional pull down menu in the work space editor and added this to it. It works when I access it from the pull down menu but I cannot add a keystroke to it to make it easier to use. I have looked at the otherpull down menus and they have a ctrl + keystroke attached but it will not work. I have had this same plug-in working with a keystroke in VW11 on both a Mac and a PC. Can you not add keystrokes to additional plugins? That would be a drag if that is the case. Anyone had similar problems and can you suggest anything. Allen Quote Link to comment
ron Posted March 24, 2006 Share Posted March 24, 2006 I have added plug-ins and keystrokes with no problems. Are you sure you doing it right? The manual has a pretty good description of the steps involved if you need help. Quote Link to comment
ron Posted March 24, 2006 Share Posted March 24, 2006 Could be a bug in 12.0 try upgrading to 12.0.1 and see if it fixes it. Quote Link to comment
