Wishlist Request: Single click toggle to turn selected line's end marker on or off.
Before VW 2021, it was possible to add or remove a line end marker (arrow) with a single click in the Attributes palette. This same action now requires a click-hold-selection which slows down the process. This is a workflow downgrade, not an improvement. Please return the ability to do this with a single click.
Given the Class Marker Style problem in VW 2022 it is even more important to simplify this toggle. Another option suggested by @Andy Broomell in the linked thread: "If they want to keep the GUI as-is, they should add a hotkey shortcut to quickly remove a marker, such as holding Cmd or Opt while clicking on the marker dropdown, in which case the marker would simply be removed with one click and the dropdown wouldn't pop up."
E|FA
1 answer to this question
