Chuck Posted March 25, 2006 Share Posted March 25, 2006 Is there a way to format custom plant tags without having to customize every plant inserted in the drawing. Quote Link to comment
islandmon Posted March 27, 2006 Share Posted March 27, 2006 Check your document's Symbol Library. Each Tag is an editable symbol. Quote Link to comment
Guest Posted March 27, 2006 Share Posted March 27, 2006 You will have to set the tag individually for each different plant definition in the symbol library as islandmom said. If you change the plant definition of A1 to display the tag a certain way, then every A1 you place after that will have the tag displayed the way you set the definition to be. However you will also have to do this for A2, A3, etc, if you want those plants in the document with that tag style as well. Quote Link to comment
