This is an example of a test worksheet I am playing around with . I am using the Project Revision History worksheet and see that there are is a "Distribution" table and fields for "name" "company" and "copies" are these fields automatically filled in some way, or are they intended to be used manually?
So far I have tried to use them manually, however when a new revision is added, I loose the "names" and "copies" (the fields go blank) which I would normally expect to stay as a record of which revision has been sent to each person.
Megan M
Thanks in advance for any thoughts on this.
3 answers to this question
