Tom W. Posted February 10, 2022 Share Posted February 10, 2022 Could someone explain how the 'Glazing Area' + 'Window Area' parameters work in Space objects? Is the Space meant to pick up the area automatically from the doors/windows somehow? I can see no way of entering these values manually or indeed have the Space take on a value automatically. All I can do is see these fields in the Advanced Properties + add them to the OIP + that's as far as it goes. I created my own 'Window Area' user field at the bottom of the OIP where I enter the value manually. Incidentally, are you only able to show User Field 1 on the OIP + none of the others? Lastly I am getting odd behaviour with my Spaces in 2022 such as changing classes in the OIP having no effect (e.g. '3D Boundary Class'): I have to go into the settings + do it there. Plus if I have unstyled Spaces I am finding a change I make to one is taking effect on all the Spaces in the file, not just the one in question: this shouldn't be the case right? Thanks. I use Spaces infrequently + in a very limited fashion so very possible this is all down to extreme ignorance. Quote Link to comment
Tom W. Posted February 18, 2022 Author Share Posted February 18, 2022 No Space experts out there able to help shed some light on this for me? Thanks Quote Link to comment
