DanS Posted July 14, 2005 Share Posted July 14, 2005 I have a floor plan in which the walls jump to an odd angle and get shortened when I select an object inserted in said wall. Short of rebuilding does anybody know why this is happening? Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted July 14, 2005 Vectorworks, Inc Employee Share Posted July 14, 2005 Dan, give us some clues: What product, what version, etc... Quote Link to comment
DanS Posted July 14, 2005 Author Share Posted July 14, 2005 Vectorworks Architect 11.0.1 on the PC, we are downloading the upgrade to 11.5 at the moment in the hope that this might help. The problem seems to arrise when we copy and paste in place walls from one layer to another. Quote Link to comment
Kevin Posted July 15, 2005 Share Posted July 15, 2005 I have had this problem too. I am using 11.5. I have not been able to isolate exactly what set of conditions might be causing this. One thing that I do is drag copies of walls to new locations by using the Option key. I have walls that disappear entirely, or part of the wall will dissappear. In one case I saw that trying to connect one particular wall to another always caused a crash. After three attempts, I deleted that wall and drew a new one and then everyting worked fine. Quote Link to comment
DanS Posted July 15, 2005 Author Share Posted July 15, 2005 I have just realised that the problem only occurs when in 2D top/plan view, switch to top view or a 3D view and the wall stays in the correct place and the inserted objects can be altered. In addition once selected I can switch back to 2D top/plan view and everything is ok. Go figure! Quote Link to comment
