Olivier-Backus Posted January 18, 2022 Share Posted January 18, 2022 (edited) Hi there, I recently mailed a lighting company for vectorworks files as they weren't in the lighting instrument library. I got back a DWG file and a STP file. When i import those they are just symbols i think. How do i make those files work and do they also work in vision and such? Edited January 18, 2022 by Olivier-Backus Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted January 18, 2022 Vectorworks, Inc Employee Share Posted January 18, 2022 You can convert the imported DWG into a Spotlight lighting device Here's the link for the Help page that goes through the basic process https://app-help.vectorworks.net/2022/eng/VW2022_Guide/LightingDesign1/Creating_a_lighting_device_from_an_existing_symbol.htm?rhhlterm=creating create created lighting light device devices&rhsearch=create lighting device and here's a link to an older video that shows the same basic workflow, its a bit dated but a lot of the basics haven't changed to much Vision symbols are not so easy to create, effectively there are only 2 options Make a Vision fixture request through the service select portal, making sure to include all required DMX modes that you need, since each mode counts as a separate fixture in Vision. create a GDTF file for the fixture since Vision can read GDTF's natively. For this you will need to go to the GDTF share websitehttps://gdtf-share.com/ Quote Link to comment
