Ramon PG Posted May 3, 2005 Share Posted May 3, 2005 My Door Schedule has several entries that I do not know what they are. They must be doors, I guess. But where are they? Is there a way to delete these entries? Thanks for any help. Quote Link to comment
Ramon PG Posted May 3, 2005 Author Share Posted May 3, 2005 There is an anwser for this one already called "schedules" Thanks anyway... Quote Link to comment
Kevin Posted May 3, 2005 Share Posted May 3, 2005 quote: Originally posted by Ramon P: There is an anwser for this one already called "schedules" Thanks anyway... Would you mind posting the link here so that others can find it. Quote Link to comment
Ramon PG Posted May 3, 2005 Author Share Posted May 3, 2005 HERE IT IS: http://techboard.nemetschek.net/ubb/ultimatebb.php?ubb=get_topic;f=16;t=001480 Quote Link to comment
J. Johnson Posted May 3, 2005 Share Posted May 3, 2005 Just for reference, you can use a space in place of the leading zero for the same effect.... -Jake Quote Link to comment
Kevin Posted May 3, 2005 Share Posted May 3, 2005 Thanks Ramon and Jake, good info. Quote Link to comment
Ramon PG Posted May 4, 2005 Author Share Posted May 4, 2005 I do have another ANSWER !!!. I like to number doors and windows with a prefix that stands for the space number they are found in. But VW sorts doors: 1-1 10-1 11-1 12-1... 2-1 it simply recognizes the first digit in the door designation regardless of decimal place. There is a way to place/sort doors doing this: 01-1 01-2 02-1 02-2... 10-1 10-2 It's a bit silly, but it works. Quote Link to comment
Ramon PG Posted May 4, 2005 Author Share Posted May 4, 2005 ...the reason for numbering like that is that you can add or delete doors anywhere in the schedule with only minor adjustments. Quote Link to comment
