Plantonia Posted April 26, 2005 Share Posted April 26, 2005 Hello: I hope someone can help me. Using VW Landmark on a Mac G-4. I am a neophyte user of the architectural features. Currently I have been designing a house. After a whole day of work today?all of a sudden, I can no longer edit the file. Did I "click" something accidentally or is there a bug? I could go back to the saved file from yesterday. But, my whole day's work would be lost. Any suggestions. Thanks, P Quote Link to comment
Travis Posted April 26, 2005 Share Posted April 26, 2005 Can you see your objects but can't "grab" them? Which version of VW? Chances are, you're on a different layer than the objects so you're not able to edit them even though you can see them. Use the Layers pull-down. There are other possibilities depending on which version you're using. Quote Link to comment
Plantonia Posted April 26, 2005 Author Share Posted April 26, 2005 I was trying to place an object, a fire place, when the whole thing just locked up. Can't click on anything at all except a line (1 single line) I made after this happened. Of course I did not realize it had happened. It's like a PDF file. Version 9.5.0 Quote Link to comment
Plantonia Posted April 26, 2005 Author Share Posted April 26, 2005 This is an imported dwg file. I have had no problems in the past. The older files all seem to be in the layer: "Mod-Detail-Site-1." But, when I click that nothing happens. I have tried several other layers as well?nothing. Quote Link to comment
Plantonia Posted April 26, 2005 Author Share Posted April 26, 2005 Got it! Just clicked "active layer." Duh. Thanks! Quote Link to comment
